R4-D4 Interchange
R4-D4 Interchange
carlsharp
Send a private message to carlsharp
I'd like to get some facts or opinions on what can be swapped on these models.
I noticed that the main case casting number is the same on my R4 (sorry no s/n) and my D4 5T. Was the same case used thru the entire 6G Thirty, R4/D4 series into the D4C?
Also, I know that the outer sprocket bearing changed from the 4 bolt cap to the 6 bolt plate in the late 40's, but are the rest of the undercarriage components interchangeable?
Thanks in advance for your thots...
Carl Sharp
Chino, CA
2xPV15; 22 2F; D4 5T
Various other oddball stuff
Vids: http://www.youtube.com/profile?user=carl4043
Thu, Jan 29, 2009 3:03 AM
Willie
Just about everything but the pistons,head and fuel tank are interchangable. Same block same crank ect as RD4
Thu, Jan 29, 2009 11:36 AM
| Kingaroy, Queensland
