r2 fuel pump
r2 fuel pump
Showing 1 to 7 of 7 results
deetwocat
Send a private message to deetwocat
can anyone tell me where i can get a kit to rebuild the ac delco fuel pump i know it is about seventy years old but it dont hert to ask it has a brass casting the seria# is 4j 658 thanks guys .
Wed, Jan 6, 2010 8:46 AM
SJ
Send a private message to SJ
It seems quite awhile ago someone on here said that I believe it was a Ford fuel pump kit had the parts in it to repair a Cat fuel pump, the diaphragm etc.so maybe that person will chime in and let you know what kit to get.
Wed, Jan 6, 2010 7:48 PM
Reply to SJ:
I think it was "Willie" that had the info......may be awhile.
Thu, Jan 7, 2010 12:05 AM
chriscokid
Then & Now Automotive
447 washington Street
Weymouth, MA. 02188
781-335-8860 8 to 5
781-355-1579 10 to 7
781-335-1925 Fax
www.then-now.com
They have everything you would need for old motors of all kinds
Very nice people to deal with and not too bad prices.
Thu, Jan 7, 2010 1:49 AM
Lance Jones
Reply to chriscokid:
Weymouth, MA. 02188
781-335-8860 8 to 5
781-335-1925 Fax
www.then-now.com
Hi from Australia , I just recently purchased diaphrams from Auto Supplies, Melbourne , Vic. #03-98733566 they are 4" and 10 holes and exactly same as my R2's and 22's They are AC units can't remember model of pump , and they still had some left . Good luck .. LJ
Thu, Jan 7, 2010 8:03 AM
Reply to Lance Jones:
Check these posts:
http://www.acmocbb.org/ACMOC_BB/showthread.php?t=776&highlight=pump+diaphrams
Thu, Jan 7, 2010 8:19 AM
bruce oz
Thank you received: 23
hello ,just to update lance info from the the above post for the 22 fuel pump diaphragm for Australian's,
early ford fuel pump 4'' 10 hole diaphragm . Auto Supplies, Melbourne , Vic. 03-98733566
goss fuel pump kit -757kt .about au$60.00
goss diaphragm -757d ,au$25.00
if you need a fuel bowl ,i have order them from here .find in the list your local bloke .
fuel bowl au$7.00 ,cork gasket au$1.00
http://www.bareco.com.au/files/chamberlain/ch11.htm
bruce oz
Fri, Jun 18, 2010 10:19 AM
Willie
Reply to bruce oz:
bruce oz
The Ford and Carter Dia. will work for the pot metal pumps but the brass pumps have diff mech. inside and all you need is a piece of dia. material and make one with a just a screw and nut to attach to rod,or get the later type and grind the crimp off the rod and just use the rubber part. I didnt think the R2 had the early style brass pump but all gas cat pumps 50,40,35,22,Ect are same pump just the arm to the cam are diff.
Fri, Jun 18, 2010 12:30 PM
