R2 fuel lines and valve
plowboy1982
Send a private message to plowboy1982
OK my r2 is plumed wrong I think has one line from rear (kerosene/ tractor fuel) tank to inlet of the fuel pump than out of pump to a brass valve out of valve one goes to carb and one goes to top of the front tank(start tank)
R2 6J
Fri, Sep 6, 2013 7:41 AM
Sounds right to me. Valve should be able to switch between starting gas tank and tractor fuel tank (that's two lines) and the 3rd one should go to carburetor.
I suppose there is an off positon where neither one flows to carb?
Just noticed that you said the line from starting gas tank comes out the top? Is there a line from the bottom of it into carburetor or change-over valve? Is there a return line fitting into the top of the tractor fuel tank as well?
Fri, Sep 6, 2013 8:47 AM
plowboy1982
It is correct I did not realize that the start tank was shorter and the line that looked like it was going to the top was really the bottom now if I new how to reseal the fuel valve and I also need the control rod that goes from the dash down to the valve
R2 6J
Fri, Sep 6, 2013 10:23 AM
