R2 Carburetor
R2 Carburetor
GMBM
Send a private message to GMBM
Have a problem with the Zenith carburetor on my R2
Tractor gets started 1 or 2 time a year most times after the first crank gas pours out the carburetor
Tractor will run and gas will not leak from carb while it is running
If I shut it off no leak and will not leak if I restart
I think it has to be float adjustment but can’t find the proper way to adjust it
The needle valve works and I did clean the carburetor and replace the gaskets with no change
Any thoughts on the problem or adjustment information would be appreciated
Thank You
Greg
Wed, Jun 5, 2019 7:24 AM
STEPHEN
Too much choke? Sticky float valve due to old gas that gets cleaned out during the run?
Wed, Jun 5, 2019 10:07 AM
Reply to STEPHEN:
My 22 had a similar problem, there is a spec sheet on the K5(?) posted on here which I found with float measurements. I tweaked the float arms "slightly" to lower the float a "hair". I no longer have the gas puking problem similar to what you are describing.
Wed, Jun 5, 2019 6:34 PM
GMBM
Reply to drujinin:
Thank you both for your reply
found the spec sheet and will try the adjustment tomorrow
Greg
Thu, Jun 6, 2019 6:45 AM
Chuck C
Reply to GMBM:
Greg
Use Sta-bil in the gas all the time.
Chuck C
Thu, Jun 6, 2019 8:07 AM
| Kingaroy, Queensland
