r and r my hydro cylinders d4
Showing 1 to 10 of 15 results
irnwrkr
Send a private message to irnwrkr
I finally took aparrt my hydro cylinders on my d4 , they look very similar to the 8f4043 and am going to replace the packing, after two hours of searching and not finding old threads I am posting this for all to respond. I do not have a part number book and do not see any numbers on the cans. the packing looks pretty straight forward to replacing any tips out there? Is there a height dimension for the front packing BEFORE it gets squished down by the four bolts? there was one thick washer and one thin one under the four bolt cover on each cylinder. the thinner one looked like a gasket. How was the thickness of the other shim determined? the packing thickness? the rear packing looks good allthough it would be foolish not to replace it?
thanks for all your help
greg
Tue, Aug 18, 2009 5:40 AM
Thank you received: 52
by the 8F designation it appears you have the late style cylinders. You can still get the rebuild parts from Cat but there have been several upgrades....like the chevron packing and shims are no longer used....packing is now a two piece affair, no adjustment required.
Tue, Aug 18, 2009 6:25 AM
Glum
OM, any idea of the cost of the rear seals 8F2685?
I nearly fell off my chair when cat gave me a price over here.
Was thinking of having two pistons made up to take more commonly available seals.
I am in the process of changing over to the late type cylinders as the old style keep blowing the seals, which I read is a common problem.
Tue, Aug 18, 2009 11:23 AM
dewets
Send a private message to dewets
Reply to Glum:
Glum, it sounds as if those parts were manufactured from 24ct gold...
Somerset West, Cape Town
South Africa
Tue, Aug 18, 2009 3:07 PM
ol Grump
Reply to dewets:
If you can, take the disassembled cylinder to your local hydraulic shop. They'll probably have seals that would work. While you're at it, it's not a bad idea to replace the brass bushings at the same time. Excessive wear on them will allow the piston rod to move up and down and that'll translate into more wear on the seals.
Tue, Aug 18, 2009 7:11 PM
irnwrkr
Reply to ol Grump:
My rods had some deep grooves running length wise and upon inspection at the front of cylinder the packing had let the rod drop until the rod hit the cast iron front cover. It looks like there should be more room there for the packing to do its job. Has anyone milled the opening out recede the the cast cover so the packing is more proud? where are the brass bushings?
greg
Tue, Aug 18, 2009 7:28 PM
irnwrkr
Reply to irnwrkr:
greg
You meant the brass eye bushings, thats a good idea,
greg
Tue, Aug 18, 2009 7:46 PM
Reply to irnwrkr:
greg
irnwrkr,
The entire 3F9378 gland is brass and that is your rod bearing support. Packing adjustment is obtained with the shims. No running into cast iron. The gland can be bored and sleeved if severely worn.
Glum,
Sorry I do not know the cost on the late piston rings.
I believe something has been lost on the old style piston seal fit. Even the new Cat seals do not fit right and require about a 0.030 in. teflon backing ring to keep them in the retaining groove.
Tue, Aug 18, 2009 9:45 PM
irnwrkr
irnwrkr,
Glum,
I thought it was aluminum,the gland has the look and color of aluminum. It is scored pretty good too. How much free play should there be between the rod and gland? maybe I can roll the gland 180 degrees and put the score at the top?
greg
Tue, Aug 18, 2009 11:23 PM
Reply to irnwrkr:
greg
I suppose aluminum would work although I have not seen it used. I'd guess about 0.010 in clearance would be about right but I have no actual specifications.
Tue, Aug 18, 2009 11:47 PM
ol Grump
If the rods are scored, a good machine shop can make new rods. If you try to run 'em scored, they'll just start leaking again in a short time as the scoring and dings will take the seals out again. If you absolutely have to use the old rods, polish 'em up with crocus cloth before putting 'em back in. Not the right way to do things but it'll work. . .for a while.
Thu, Aug 20, 2009 7:36 PM
