R-4 Connecting Rod Bearing Dowels
Showing 1 to 7 of 7 results
Jeremy Williams
Send a private message to Jeremy Williams
Hi all,
I just acquired an R-4 yesterday that was stuck. After finishing the engine disassembly today I noticed that a couple of the dowels that hold the rod bearings (part# 4b47) in each half have been partially drilled out. Does anyone know if these can be punched on through the connecting rod once the wrist pin bushing is removed, or tap them down from the wrist pin end? I am also looking for these pins if anyone has an idea where to start. As always any help is much appreciated.
Jeremy
Fri, Jun 24, 2016 9:12 AM
jmvmopar
Fri, Jun 24, 2016 9:58 AM
STEPHEN
Sounds like rods are drilled to oil the wrist pin?
Fri, Jun 24, 2016 12:12 PM
Jeremy Williams
Reply to STEPHEN:
:doh: I never thought to try 4B0047! Thanks for the help. Yes the rods are drilled to force some oil to the wrist pin bushings.
Jeremy
Fri, Jun 24, 2016 8:47 PM
willitrun
Send a private message to willitrun
Reply to Jeremy Williams:
Jeremy
could you thread them, screw a rod in and use a slide hammer ?
Sat, Jun 25, 2016 9:50 AM
Jeremy Williams
Reply to willitrun:
Willitrun,
That is another great idea to try. I will tap them and see what happens. Thanks.
Mon, Jun 27, 2016 8:29 PM
Jeremy Williams
Willitrun,
Thanks for the help again guys. I was able to tap the pins 1/4-28 and pull the dowel out easily. I also found the replacements and have them ordered.
Jeremy
Thu, Jun 30, 2016 5:37 AM
Thank you received: 78
Jeremy
The same approach is used on the dowel that retains the countershaft rear bearing on the D2. Have to remove two frost plugs, then screw a 10-24 (I think) screw into the dowel to extract it (if it doesn't just fall straight out).
Thu, Jun 30, 2016 7:01 AM
