R 2 Clutch
R 2 Clutch
catrat
Send a private message to catrat
Question on my R2 steering clutches where rebuilt about 10 years ago. I have been able to run it every summer from that tim but due to health can,t this summer. I have the sticks tied back [released] can i just run the engine in gear and shine them up so they don,t stick.
Thanks:noidea:
catrat
Thu, Sep 5, 2013 10:43 PM
I do exactly that to my D2 occasionally to keep them free if i don't want to take it out for a walk!!
Fri, Sep 6, 2013 12:20 AM
Reply to dpendzic:
Have someone crawl underneath and remove the Drain Plugs in the Final Drives.
Drill holes in them so that sitting from non-use, the Finals will not fill with condensation or rain/snow water.
I suggest 1/8" holes in the centers of them, then replace to keep Rodents out.(Yes, Mice will get in them)
This will help in your situation.
Fri, Sep 6, 2013 1:00 AM
It helps to keep the holes in the drain plugs of the steering clutch (and main clutch) compartments open if you put in a cotter pin that can rattle around some.
D2-5J's, D6-9U's, D318 and D333 power units, 12E-99E grader, 922B & 944A wheel loaders, D330C generator set, DW20 water tanker and a bunch of Jersey cows to take care of in my spare time๐Ÿ˜„
Fri, Sep 6, 2013 1:10 AM
catrat
Thanks to every one for the replys. I think i have the plugs dilled now but will check what my memory can,t recall ๐Ÿ˜ž
catrat
Fri, Sep 6, 2013 4:22 AM
| Kingaroy, Queensland
