Quiz
Showing 1 to 9 of 9 results
johan7
Hello , I had to do with this D2 in the late 50's . Recently this machine was for sale . I noticed a mistake : [attachment=33620]5U 16621 2013.jpg[/attachment]
I noticed the same mistake with this D10 , that I found on the web : [attachment=33621]D 10N.jpg[/attachment]
Have you ever seen this mistake ? I did more often . Even at a brand new asphalt paver .
Question : what is the mistake ?
Have a nice day , johan7
Mon, Feb 1, 2016 5:15 PM
Wombat
Donor
Tracks are fitted in reverse
Mon, Feb 1, 2016 5:21 PM
mrsmackpaul
Reply to Wombat:
I reckon Wombats onto it
but why does it make a difference ?????/
Paul
Mon, Feb 1, 2016 6:11 PM
catsilver
Reply to mrsmackpaul:
Paul
It wears the track bushes and sprockets out faster, and has been covered in depth in previous topics.
Mon, Feb 1, 2016 6:45 PM
ronm
Reply to catsilver:
The backs are on trackwards...
Mon, Feb 1, 2016 8:33 PM
Bruce P
Thank you received: 38
Reply to ronm:
...bassackwards...
Mon, Feb 1, 2016 8:39 PM
kracked1
Reply to Bruce P:
...bassackwards...
Those are the rare back dragging finish dozers.
Mon, Feb 1, 2016 8:51 PM
mrsmackpaul
Reply to catsilver:
thank you Catsilver but thats not the answer Im really chasing
I guess the reason I ask isnt for me and no doubt it has been covered before in detail but I dunno I have been on here for a few years and dont recall it spoken about
So with out going into a real long winded explanation can someone explain to people that may not be as experienced as others quickly and with out a whole heap of waffle why and how this happens
A bit like the tyres on the front of a grader and why they are put on backwards hmmmm ? would it still be called backwards if they are running the correct way for those wheels etc etc. Dont want to reinvent the wheel just a short explanation for people that are newer to the hobbie who may not have 50 years experience running tracked machines
so I guess someone with the gift of the gab could they quickly explain why its done how it helps to prevent track and pin sprocket wear and a actual correct reasoning that cat use for this thought pattern
does it say it somewhere in a Cat book might be easier to scan a page whack it up !!!
thanks in advance
Paul
Tue, Feb 2, 2016 2:25 AM
catsilver
thanks in advance
Paul
Each track link pitch has a bush pressed in one end and pin in the other, in forward motion, the 'pin' end of the links enters the sprocket first, so the pin turns inside the bush as the link bends to meet the sprocket which drops over the next bush. This is underneath the sprocket, under heavy load.
As the track leaves the sprocket at the top, the bushes then actually turn against the sprocket teeth, causing wear on the bush and sprocket, but they are under little load. When travelling in reverse, the bushes turn on the sprocket as they enter it.
This is why reverse drive side wear on the bushes and sprockets is always greater on a dozer.
Now put the tracks on the wrong way round with the bushes entering first in forward direction, underneath, under heavy load, with plenty of dirt round them, and you will see a massive increase in external bush wear as the bushes are turning against the sprocket under load. ,
Tue, Feb 2, 2016 5:08 AM
mrsmackpaul
Reply to catsilver:
perfect catsilver thats along the line of what I was asking all to often we assume the person on the other end of the computer knows what we are on about and a lot of people on here are having their first experience with a crawler tractor
A lot more people on here are a lot better at explaining stuff than me thanks for catsilver
Paul
Tue, Feb 2, 2016 5:39 AM
