Question on D6C 99J2111 Oil Change
Showing 1 to 6 of 6 results
dbclem
Send a private message to dbclem
Hey guys, new to the form, just purchased a 99J series D6C and am trying to get everything up in shape before I use it much.
I changed out the oil on the transmission, steering clutch/brake and flywheel clutch today. I drained the 3 plugs at the back and the one under the flywheel. I cleaned the magnetic screen assembly, the flywheel sump screen and installed a new filter.
My question is does the flywheel housing refill from the transmission/steering/brake compartment. My book shows it takes 27 gallons for all these systems, which I added and after firing the dozer up the dipstick below the seat is showing full. I don't see any plugs or stick to check the flywheel clutch housing, am I missing something. I can't find anything specific to this in my books.
Thanks in advance, I'm sure this is the first of many questions.
Wed, Dec 24, 2025 2:43 AM
bluox
Thank you received: 11
Look in your parts book should be a gauge on right side of clutch housing for clutch.
Also shown in maintenance book.
Bob
Wed, Dec 24, 2025 4:30 AM
dbclem
Thanks for the reply back Bob, so there is a sight gauge or check port on the right side of flywheel bell housing? I'll look again, on my next trip to it, unfortunately it is about 1.5 hours away on a farm. I did look that area over pretty good yesterday, but may have missed it, I've been known to do that. Is that where you would add fluid as well? I'll also take another look in my maintenance book. Appreciate your input.
Wed, Dec 24, 2025 1:25 PM
EZCAT
Thank you received: 20
Reply to dbclem:
If i am thinking correctly the flywheel gets oil from a oil lube pump, and the excess gets pumped back to trans , so gets filled up that way
EZ
Wed, Dec 24, 2025 2:05 PM
dbclem
EZ, thanks I think your memory is correct, I looked in my maintenance book and the only check and fill points they reference are under the seat. I hate to do it, but just to be 100% certain, I may take the top cover off of the flywheel housing. That will give me the opportunity to adjust the clutch one notch, the snap in is just a bit light. I think my book was indicating it should snap in at about 50 pounds of pressure.
Just got this dozer, it was one used by a township, the good news is I have pulled every filter, screen and magnetic plug and everything looks great. The exception to this is the final drives, I checked them and they were full, but I think I will put some new oil in them as well, then everything will have been changed. I am thinking about going with a 75W-125 synthetic oil in these. I know there is a lot of debate on the oil to use in the finals and also think this may be the weak link so want to do it right. Most of the hours on this will be done in warmer weather, but could see some work around 40 degrees or so. Wondering what the best viscosity would be to go with, I know the book shows 50W, but the flow is so much better on these new synthetics.
Wed, Dec 24, 2025 2:26 PM
Thank you received: 41
Transmission, bevel gear, flywheel clutch and steering clutches are all fed from one source. There is no separate fill or dip stick for the clutch.
Capacity is 26 gallons SAE 30wt or Cat TO4 (TDTO-30)
Finals are SAE 50wt per Cat Spec.
Wed, Dec 24, 2025 9:16 PM
dbclem
Old Magnet, thanks much for the input, I have read several of your responses on here and you seem to have them well dialed in. So it sounds like I am in good shape on the refill that I did. I did go with the Cat TDTO-30 based on the claim of higher clutch life. I can be cheap on a lot of things but didn't want to take a chance on that. Really it wasn't significantly more than other major brands at $100 per 5 gallon.
After doing some research on the oils, I think I will end up putting in a 50W TO-4 rated oil in, I like the synthetics in some arenas, but don't want to risk bronze damage from the GL5's which contains active sulfur-phosphorus protection. Not wanting to start an oil war, just what I'm going to run in this one. I'm an old man and this is an old dozer so neither one of will probably work too hard.
Thanks again for your input, much appreciated!
Merry Christmas to everyone be safe and have a great and safe 2026!!
Thu, Dec 25, 2025 2:56 AM
