Question concerning clutch
Showing 1 to 10 of 16 results
blwatson
Send a private message to blwatson
I have a question concerning the proper position to leave the clutch when getting off the dozer and leaving it to idle. I have a D47U. I do not have a lot of operating experience, certainly compared to a lot of the members here. I was told when I bought the cat to get it on level ground, lower the blade, put it in neutral, set the brake, and engage the clutch. I have been told by others not to engage the clutch. Could someone please let me and others that may not be certain, what the proper procedure is. I did not see anything in the operators manual that addressed this. I also block the tracks if I am on any kind of incline at all. I did a search but did not find anything but I am sure this has probably been discussed before. I am concerned about safety and wear and tear on the machine. Thanks in advance for the help.
Fri, Mar 18, 2016 5:13 AM
by engaging the clutch you prevent the pilot bearing from turning and wearing out. It also locks the transmission shifter in neutral so you don't accidentally knock it in gear when getting off and on
Fri, Mar 18, 2016 5:36 AM
rmyram
I was always taught to place any hand clutch machine in neutral and engage the hand clutch, whether it had tracks or wheels. in my D6 manual it states when leaving the engine idling, that you put the transmission in neutral, and the forward reverse lever in either forward or reverse and engage the clutch.
my thought is that if the tranny is in neutral and the clutch is engaged, then if someone inadvertently falls against the lever getting on or off the machine then it isn't going to move, it is just going to disengage the clutch.
a d2 doesn't have a fnr lever so I would place it in neutral, set the brakes, and engage the clutch.
Fri, Mar 18, 2016 10:21 AM
Walt D7-3T
Send a private message to Walt D7-3T
Reply to rmyram:
All,
I just realized something, after reading this thread, that I NEVER realized before. Back when I was a teenager I drove many different wheel tractors on my family ranch. I later finally graduated to our Cat D7's (we had two).
On those I never engaged the clutch while the engine was running but I DID make sure the transmission was in Neutral.
What I just realized was that any and every time a wheel tractor was left running with no one on it (even in cars and trucks) that foot clutch was spring loaded and was engaged.
So, it seems that my practice of NEVER engaging the clutch on our Cats was all WRONG. Sheesh, was I ever in error (to say it politely).
Fri, Mar 18, 2016 12:57 PM
johan7
Reply to Walt D7-3T:
All,
Hello ,
In my opinion it is indicated in any operator's manual that you should put the transmission in neutral , engage the clutch , lower any equipment before you leave the machine .
In this position the transmission is also locked in neutral by the linkage between clutch lever and transmission .
But there is something else : if you leave the machine by just throwing out the clutch and the transmission in gear , think about what can happen when the pilot bearing will freeze .
Just think about it !!!!!
Have a nice day , johan7
Fri, Mar 18, 2016 3:41 PM
7upuller
Reply to johan7:
Hello ,
Hey Team,
At a PlayDay, two people were going to switch operators. One climbed on the track when the D4 was stopped. As they were switching spots, one grabbed the clutch handle as a hand hold, and the tractor jumped as it was left in gear. The other operator jumped to his safety landing and rolling on the ground. Sad thing, is one of them was well experienced and even owns tractors himself. The other owns a Cat, but is a newbie.
Always put tranny in neutral and engage clutch. If you are climbing on a tractor that someone else parked, always ASK if that procedure was done before climbing on. No one got hurt, except their pride, and a little ass chewing I did. Hopefully with that experience they have learned something that they can preach to others. I have heard many of stories where a person got killed from similar situations.
Glen
Fri, Mar 18, 2016 5:28 PM
mrsmackpaul
Reply to 7upuller:
Hey Team,
Glen
by putting the trans in neutral and engaging the clutch you then prove the tractor is out of gear a bit like a gun you should always prove it isnt loaded that way you know its safe
Like electrical circuit always prove it is dead before putting starting work on it never trust a circuit breaker always test
anyway thats my thoughts
And like Walt says a normal clutch on anything else is always engaged once your foot is off it
Paul
Fri, Mar 18, 2016 6:23 PM
catsilver
Reply to mrsmackpaul:
Paul
The first lesson on operating my old Dad taught me was to NEVER climb off a machine before engaging the clutch and locking the parking brake, I was only nine years old at the time, the following year one of his workmates failed to do just that, and ran himself over with a D2 leaving seven children under eleven years old. Don't leave anything to chance.
Fri, Mar 18, 2016 9:32 PM
blwatson
Reply to catsilver:
Thanks to all for the feedback. Glad to see all are in agreement. Do not see that happen here very often. Hope it may save someone from having a serious mishap such as the one mentioned by catsilver.
Fri, Mar 18, 2016 9:57 PM
Sasquatch
Reply to blwatson:
Very good discussion here, thanks blwatson for asking the question and starting this thread. The reasons that have already been stated are why I made it a point to mention "transmission in neutral, main clutch engaged" as one of the pre-startup control settings in the D2 and RD6 startup videos I put on YouTube a few years ago.
I remember a thread that was posted here on this bb several years ago now (tried to find it, but "search" let me down) that warned of starting an oil clutch equipped machine with the clutch lever disengaged but the transmission still in gear. The owner was showing his grandkids how he started his D2, it was sitting in the shed so everybody was crowded around the machine. It was a colder day so the oil was thick and put higher than usual drag on the clutch, and as soon as he started cranking the diesel the D2 lurched forward a foot or so and gave them all a good scare, luckily nobody was hurt but a good lesson was learned. Much the same effect as a siezed pilot bearing could make happen, like johan7 mentioned.
Fri, Mar 18, 2016 11:30 PM
7upuller
Reply to Sasquatch:
Hey Team,
Sasquatch has a good point. Thank you Sasquatch for your great videos, I think you have a talent in them. At a time when it was cold out and had to start my 36a, I started it in gear, with clutch disengaged. I had to do this when I first purchased it, before fixing clutch brake and changing oil in clutch. The problem was once started, I couldn't get it in gear. Anyways, I was shocked that even when clutch disengagedl the Cat D8 moved ahead just from thick cold oil drag on clutch. Great point Sasquatch. I've since fixed cat and don't have to go there, and start in neutral with clutch engaged. I was not in close quarters and no one was near by.
Sat, Mar 19, 2016 1:42 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
