question about D4 hydraulic options
captainhowdy
Send a private message to captainhowdy
i have a D4 6U 1953 model with a 4s blade. my question is there is a valve block on the right front fender where the flow from the hydraulic control unit divides and goes to the lift cylinders. this block also has a couple of blocked off ports and a lever on top. is this made so a rear hydraulic implement can be selected and used while disabling the blade lift?
Fri, Oct 27, 2017 8:08 PM
old-iron-habit
Yes, it is the valve diverter.
Fri, Oct 27, 2017 8:28 PM
