ques on Cat part number
bobcatfour
Send a private message to bobcatfour
I was told that the CAT part number, for pony conn rod bearings, would be for half a set. In other words, one half a bearing for one rod. Why would anyone ever need to buy one half bearing? The boxes I saw were packaged 2 pieces per box, enough for one rod. Any reason the part number would be for half a box? Part number I am dealing with is 3B7938, but this may be an after market number.
Wed, Nov 21, 2007 11:58 PM
dtallon
Send a private message to dtallon
When I looked up that part number in the Cat system, the picture shows half a bearing, but there is a note on it that says "This part number denotes two identical half shell bearings". I would guess from that note that you should get enough for one rod by just ordering one of that number.
Thanks,
Dave
Thu, Nov 22, 2007 12:15 AM
SJ
Send a private message to SJ
Reply to dtallon:
Thanks,
Dave
The parts book lists the 3B7938 as .020" under size & it calls for 4 bearings for one engine when that higher SN D4 6U book was printed but the way Cat always changed numbers they could have come up with one number to supercede this one & put two bearings in one box but I,m not sure if they did or not.You would have to check at a dealer in their parts computer or NPR to see.
Thu, Nov 22, 2007 1:57 AM
KidNV
Send a private message to KidNV
Reply to SJ:
bc4, its for the 2 halves..
Thu, Nov 22, 2007 5:11 AM
bobcatfour
Reply to KidNV:
Thanks for the replys! The number/parts issue has been settled between me and the parts dealer!
Tue, Nov 27, 2007 12:56 AM
