yes its almost the same as a ten (bet 1 inch) its only one other nossle (biggar hole perhaps) inside.
does anyone know where to buy the top lid of the carb, as like many mine is cracked too and need replacement . thanks marco
John,
The most critical thing is making sure you get the center pedestal fitted with the proper size gaskets. Too thin and all it will do is suck air...too thick and you will crack the pot metal bowl cover. Test fit it several times. Make sure the pedestal does seal top and bottom. There should be a slight gap between the top cover and bowl when you fit the top cover with the proper gaskets above and below the pedestal. Tightening the screws will then assure a good seal. If the cover fits up tight without the screws...then chances are the gaskets are too thin. It might work at first but as soon as the gaskets have soaked, then dried...they will shrink and lose the seal. No amount of cranking will ever start it.
Pat
Hi Guys I think that Bill Campbell has everything you guys are looking for including the top cver on the carb. Jason
