Push - pull hydraulics ?
Showing 1 to 6 of 6 results
johan7
Hi everyone . Got this picture from a friend . This RD8 is equipped with a rather singular hydraulic system . One ram goes in while the other goes out . Question 1 : who was the maker of this system ? The name CARGO is on it , maybe that helps .
The push arms are so long I can"t clearly see the ends . It looks as the trunnions are beyond the tracks .
Question 2 : Who knows about this ? Thanks in advance . Johan7 [attachment=36690]RD 8 Cargo.jpg[/attachment]
Sat, Jul 2, 2016 12:00 AM
sdmuleman
Send a private message to sdmuleman
Can't tell for sure, but I'd suspect that setup is because they're both single acting cylinder, hence you need one for lift and one to push the blade down. Single acting is easier because you don't need to have a gland that holds pressure, just piston seals. Or it could just be a way to get more force without going to a larger cylinder, but I'd think just going to a slightly larger cylinder would be easier than adding a 2nd complete cylinder.
Sat, Jul 2, 2016 1:20 AM
Reply to sdmuleman:
I believe the manufacturer is "CARCO" of winch fame. Push arms actually attach to rear draw bar. No trunnions.
Sat, Jul 2, 2016 2:10 AM
Thank you received: 140
Hi, Johan7.
It would be worth bearing in mind too that this would have been a low-pressure, high volume system, as were almost all hydraulics of that era. With the low pressure and the reduced piston surface area of the rod side of the piston, they did not have a lot of power on the 'In' stroke, hence the cylinder 'pushing ' for the blade lift.
Sat, Jul 2, 2016 7:34 AM
68dually
Send a private message to 68dually
Hi, Johan7.
Looks like he was cleaning up a logging job! That's my cup of tea!
Sat, Jul 2, 2016 8:26 AM
old-iron-habit
Reply to 68dually:
Whats really interesting is that the cylinders to push down are also smaller and of less mechanical advantage as the cylinders tht lift the blade. Makes sense as there is blade weight to help go down and more lift is required to lift and push as when grubbing stumps. Over all I find it a very interesting setup. It would be cool if there is still one around somewhere.
Sat, Jul 2, 2016 9:32 AM
Reply to old-iron-habit:
Hi, O-I-H.
If there ain't one still around, why not "roll-yer-own"? All yer need is a 1H D8, some low pressure rams and a pump with the control valve, a pile of scrap iron and the appropriate cutting and welding gear. Might help to keep you from gallivanting all over the countryside for a while. LOL.
Sat, Jul 2, 2016 9:42 AM
