Push or pull Fan shroud and fans
Showing 1 to 10 of 10 results
Basdas
Send a private message to Basdas
 [attachment=67202]C778320A-37A3-444B-AFAE-045F3C276304.png[/attachment] [attachment=67202]C778320A-37A3-444B-AFAE-045F3C276304.png[/attachment]Good morning I had such a good response to my first question I thought I would throw in my second question on a new topic. I have a 1958 D4 7U42585 I have two fingers the stock four-bladed fan with fan shroud. The previous owner also had the pusher fan which is six blades but it takes a different fan shroud from my understanding.1. Which fan would be better to use in Southern California a push or a poll fan?2. and where would I look for a push your fan shroud since they took different fans rounds depending on if you had a pull or push fan? Also the wire mesh protector that goes over the fan shroud.Thanks again for any input advice or where to acquire these.  [attachment=67201]A0A43107-40A5-4637-B854-643553CE52E1.png[/attachment][attachment=67202]C778320A-37A3-444B-AFAE-045F3C276304.png[/attachment]
Thu, Mar 24, 2022 10:20 PM
Basdas
I apologize not too good with the computer hopefully you found my questions buried between the pictures that are duplicated.
Thu, Mar 24, 2022 10:21 PM
Kurt Bangert
Thank you received: 43
Reply to Basdas:
Basdas - I can't help you with the specifics of the question, but I would recommend joining up so that you can access the library where you can get to the parts catalogs for these machines. It's well worth the small investment! I have found it very, very helpful.
Thu, Mar 24, 2022 10:29 PM
Basdas
Reply to Kurt Bangert:
Thanks for the advice my plan is to join right now I’m spending most of my money supporting Caterpillar and the parts they supply so Get my machine running. But yes my plan is to join thanks for the advice I do appreciate it very much.
Thu, Mar 24, 2022 10:39 PM
Reply to Basdas:
Suction fan will make engine run cooler, but hot and dusty for the operator.
Thu, Mar 24, 2022 10:59 PM
Glum
I would make sure the rest of the machine is fully functional before worrying too much about the fan type.
It's been my experience that if you have a suction fan and are brush clearing, you need to keep a good eye on the temp guage and have a thin stick or wire to scratch the leaves and twigs out between the #44 hydraulic control and mesh screen every few hours.
Thu, Mar 24, 2022 11:35 PM
pstine1
Send a private message to pstine1
Reply to Glum:
Wow, Those are some fresh Track pads..
Thu, Mar 24, 2022 11:42 PM
Basdas
Reply to pstine1:
There’s a screen? Where can I get one? I don’t have that. Where would I get fan shroud for push fan?
Found these part numbers for wire mesh guard
8f7808 and 8f7807
Fan shroud 4f9114 and 4f9113
Looking for shield part #
Fri, Mar 25, 2022 12:34 AM
Thank you received: 77
Reply to Basdas:
8f7808 and 8f7807
The shroud sits behind the fan and in front of the engine. The screen sits in between the radiator and the #44 hydraulic control in front. That heavy #44 guard that's leaning forward needs to be bolted back to the radiator at the top to protect it. You can search machinerytrader.com for those part numbers. Also post a want ad on the For Sale here - someone may have a spare to sell you
Fri, Mar 25, 2022 1:24 AM
Thank you received: 54
most dozers had push fans to keep the rad clear. any farm crawlers that worked grain crops tended to have push fans for the same reason.
most modern large farm tractors have reversible fans some are automatic being electrically driven so they simply use a timed relay to stop and reverse the fan. others are mechanical.
its important to regular clear the rad when working in dry, dusty, muddy and leafy conditions many farmers have lost machines due to fires from dirt and vegetation build up around radiators and transmissions.
dont use wire or sticks to clear the rad to big a risk of puncturing the core. use a hose or compressed air instead. old refillable water fire extinguishers are good for this you can charge them with water and air or just air. the uncle worked for a bailing contractor they always had a couple filed with water when they were working in dry conditions.
Sat, Mar 26, 2022 11:39 AM
Thank you received: 62
Reply to trainzkid88:
A lot of different things come into play as which fan will give the best results. A push fan was hard for me to find 30 years ago for a 9u D6. But doing dozer work it seemed a good idea. Without side screens on the engine not sure how much it helped.
Did more farming than dozing with this tractor, the pull fan did more cooling on hot days. After a cold day on the tractor I put the pull fan back on. Get the warm air from engine blown back at you rather than pulling cold air past you. Again in grain stubble in sticky ground more straw got sucked off the tracks than got sucked up from the front with a pull fan.
Sat, Mar 26, 2022 11:15 PM
