Pup motor on a D2 3J
D2 Caterpillar
Send a private message to D2 Caterpillar
Hello all you Wizards out there!!
I can not get this motor to fire up. I have great spark, and lots of fuel.
Could it be that the compression low?
If so, should it be re-ringed, this cat has been sitting for a long time. Any suggestions are most welcome.
tim
Sun, Oct 8, 2017 11:47 PM
They were not very high compression to start with and will run when very worn out, so i would not give up yet.
Quick, easy check is swap the plug wires in the mag cap. Been more than one that was fixed like that!
Valves could be stuck and 0 compression. Hold your thumb over the plug hole while you crank it to find that. It doesn't take long to pop the heads off and check things out in there. Just have to drain the coolant first! Head gaskets can almost always be reused or new are $10-15.
Mon, Oct 9, 2017 1:27 AM
D2 Caterpillar
[quote="ccjersey"]They were not very high compression to start with and will run when very worn out, so i would not give up yet.
Valves could be stuck and 0 compression. Hold your thumb over the plug hole while you crank it to find that. It doesn't take long to pop the heads off and check things out in there. Just have to drain the coolant first! Head gaskets can almost always be reused or new are $10-15.[/quote]
Thanks for the advise, I will give that try!!
tim
Mon, Oct 9, 2017 2:07 AM
Reply to D2 Caterpillar:
tim
If its no compression then the valve lifters are stuck, usually happens when sitting for a long time.
Mon, Oct 9, 2017 3:40 AM
oldbeek
Use a compression gauge. Mine had 80 and ran great.
Mon, Oct 9, 2017 11:17 AM
