pulling track with out pin removal????
zep
Send a private message to zep
I'm trying to drive the pin out of my d25u and I'm not having any luck.Can the adjuster be ran back far enough to remove the track without taking the master pin out?Thanks,Tim
Sun, Dec 11, 2011 2:45 AM
zootownjeepguy
When you beat on the pin are you backing up the link with a heavy sledge hammer head? If you're just whacking the pin it will only bounce. It helps putting a bunch more weight behind the link to soak up the inertia.👍
Rich Salvaggio
D2 5U9917
Sun, Dec 11, 2011 3:17 AM
Steve A
Reply to zootownjeepguy:
Did you loosen the track adjuster, that is a feat in itself
Did you remove both master pin retainers
Has the pin moved at all? Keep in mind this is a small sledge hammer job, not a ball peen job
If there is much wear on the master pin it will help to draw in the links adjacent to the master link to relieve pressure on the pin
Sun, Dec 11, 2011 9:07 AM
catsteve
Send a private message to catsteve
Reply to Steve A:
I backed the adjuster right off on my D24U. The rails will slip off (with help). This was with a 30 link chain,
hope this helps
Sun, Dec 11, 2011 10:24 AM
gauntjoh
Librarian
Thank you received: 5
I was able to remove the track from both my D2 and R2 (4J - same as D2) tractors without splitting the track, just be backing the track adjuster right off and manhandling the track over both idler and sprocket. I had the tractor jacked up at the time.
Mon, Dec 12, 2011 1:34 AM
Jack
Reply to gauntjoh:
Seems they ought to come off unless they are new and don't have much fles in them. It's been my experience that you have to get onto a side hill waist deep in poison oak. They'll come off all by themselves.
Mon, Dec 12, 2011 7:57 AM
willitrun
Send a private message to willitrun
Reply to Jack:
right, or knee-deep in mud will assure they'll come off.:Cry:
Mon, Dec 12, 2011 10:32 AM
catsilver
Reply to willitrun:
I once changed over a pair of D4 tracks, as I was told to do, without splitting them, and true to form, one came off very easily while digging into a ditch to winch out the 4 x 4 timber tractor which was aleady stuck after backing down into a ditch for anchorage to winch out its loaded trailer. Father was not very happy, two hours away from home on a saturday morning!!
Mon, Dec 12, 2011 4:02 PM
mcclaar
Send a private message to mcclaar
Reply to catsilver:
Took both tracks off my D2 without splitting as well. A long heavy pry bar makes it alot easier!!!!!!!!!!!!
D2 4U-2045
Mon, Dec 12, 2011 8:07 PM
