pulling brake drum on d2 ?
zep
Send a private message to zep
Im replacing the steering clutches on my d2 and the brake drum won't come off, do i really need to pull it off in order to put every thing back together?Thanks,Tim It is on a d25u
Mon, Feb 6, 2012 8:49 PM
ol Grump
Tim.
I hate to tell you but the steering clutches are inside the brake drums. You'll have to take the finals complete with brake drums off. This is my least favorite job on Cats, I take the cross shaft off, then move the track frames ahead and tackle the finals. If the steering clutches weren't stuck you have a good chance of just sliding the finals off after you get all the bolts out. If the steering clutches are stuck, it's usually a case of trying to pry the finals off. With a stuck steering clutch, I'm at about 50-50 of getting the final off without breaking the brake drum.
Mon, Feb 6, 2012 9:25 PM
josh
Thank you received: 13
Reply to ol Grump:
Tim.
It depends on what won't come off, if you have been able to take off the whole final drive assembly with the brake drum and cannot get the drum off the tapered spline shaft and you do not plan to go further into the final drive to replace seals and bearings, and the drum is ok, then you can leave the drum where it is. If the drum will not come off the clutch pack and you cannot get the final drive assembly off, that is a whole different story, often requiring distructive force, torch etc. and replacement of most of the steering clutch components.
Tue, Feb 7, 2012 12:30 AM
Jack
Reply to josh:
I don't see it being explained here and maybe it's not necessary, but understand that when you pull a final drive, the clutch pack stays on the tractor and the brake drum stays on the final drive. You need to pull off the clutch pack from the shaft and take it to a press for disassembly and reassembly. Don't try to take a clutch pack apart in your garage with common hand tools. When the bolts let go it's like an explosion. Hopefully, your dealer or shop will still have a drum on hand to line up the outer clutch plate teeth when you put it back together and you won't need your old funky one to try to get everything straight.
Have fun!
Tue, Feb 7, 2012 10:18 AM
the Farmer3
Send a private message to the Farmer3
Reply to Jack:
Have fun!
Zep,To answer your question.No,you don't have to pull the brake drums off.You can center the discs and use a straight edge to line the teeth up.
Fri, Feb 10, 2012 9:42 AM
