pull type Cat grader
Showing 1 to 10 of 15 results
kellyb
Send a private message to kellyb
Hi, I have a pull type Cat grader, the SN is 8H500. We use it on the farm to run thru our field drainage ditches, it has a 12' moldboard and has been converted to hydraulic cyl. for the main control arms. I still have the Cat engine that ran the grader it has a SN of 4D1060 and I had it running a few years ago. It has a Fairbanks Morse magneto. The engine weighs 325 lbs.
I have surfed for detailed info on both of these and I cant find anything. If you have some info on year made, rare, etc. please let me know. Thanks.
Tue, Dec 5, 2006 7:22 AM
SJ
Send a private message to SJ
The grader is listed as a #44 grader & production started in 1937 according to the Cat SNID book but the engine year is blank & not listed as to what year it was first produced.That,s all I have on it.
Tue, Dec 5, 2006 8:15 AM
bruce oz
Thank you received: 22
Reply to SJ:
hello kellyb,the cat 44 single frame grader was made from 1937 to 1942 and the weight is 8,170 lbs with power control fitted ,the one you have having a high number i would say it was built in the later years ,hope this helps,bruce oz
Tue, Dec 5, 2006 12:12 PM
SJ
Bruce, Of all the pull graders I,ve seen & been around here in my area I never saw one with a small engine on it like this one you pictured. Cat graders were as scarce as hens teeth to begin with as most were Galion & Austins & Adams pull behind graders.
Tue, Dec 5, 2006 9:27 PM
kellyb
Thats the best info Ive been able to get ever, can you tell me more or send be more pictures? Thanks alot.
KB
Wed, Dec 6, 2006 1:47 AM
Willie
Reply to kellyb:
KB
Kelly when I get back home I'll lok for pics of mine and send yo many have had engine replaced with briggs or wis.
SJ ; what they did was put same setup as on No.10 or11 on a No.44 frame and power the controlbox with a little engine hanging down below it
Wed, Dec 6, 2006 1:56 AM
OzDozer
Reply to Willie:
From the 1936/37 Cat pull grader catalog ..
http://img26.exs.cx/img26/5303/pullgraderno444vv.jpg
Wed, Dec 6, 2006 6:21 AM
bruce oz
Reply to OzDozer:
hello all ,here is a non powered 44 on ebay ,will se how much it sell for ,bruce oz
http://cgi.ebay.com/PULL-BEHIND-1920s-CATERPILLAR-ROAD-GRADER_W0QQitemZ7602981755QQcategoryZ61568QQcmdZViewItem
Wed, Dec 6, 2006 6:56 AM
terrywelch_archive
Reply to OzDozer:
Kinda like this one. We pulled this one out of the brush a few weeks ago. The engine was replaced with a Wisc years ago. Owner still has orginial engine. Note the optional siting pin above the front pedistal, a farmer add on. I have to try and help him get this going I will post some other pictures from the farm later. The number on this grader is 8H761.
Terry
Wed, Dec 6, 2006 7:00 AM
Steve Melton
Send a private message to Steve Melton
Reply to terrywelch_archive:
Terry
Thanks for the info and the pics. on the Cat 44. I never knew they made a #44 with a power ubit on it. I learned something new.
I have a #44 that was my first ever restoration. It is like your first kiss, you never forget it. Thanks, Steve
Wed, Dec 6, 2006 10:23 AM
kellyb
Reply to Steve Melton:
Do you have any pics of your 44 restored?
Wed, Dec 6, 2006 10:32 AM
