PTO unit identification
Showing 1 to 10 of 12 results
jstandle
Send a private message to jstandle
This PTO unit came with some other stuff we recently purchased. We were told it might fit a D6 9U and/or D5 but the bolt pattern doesn't look right to me.
Some part numbers on the unit are as follows;
6B7553
S2368
1B3479
S2377
Measurements between the top two holes is 3-3/4, between center holes looks to be 7-1/4" and the bottom is 2-1/2".
Anyone have any ideas what this might fit?
Here are some pictures.
[attachment=52546]20190131_162512.jpg[/attachment]
[attachment=52547]20190131_162516.jpg[/attachment]
[attachment=52548]20190131_162519.jpg[/attachment]
[attachment=52549]20190131_162742.jpg[/attachment]
[attachment=52550]20190131_163743.jpg[/attachment]
Thanks!
Jordan
Fri, Feb 1, 2019 8:40 AM
josh
Thank you received: 14
The 6B7553 leads to PTO groups, 3B1179, 2F7984, and 8F6315, used on 6G, 2T, 5T, 7J, 6U, 7U, etc.
Fri, Feb 1, 2019 10:49 AM
That's a PTO for a 2Hxxxx series D6. 1B3649 PTO Group.
Fri, Feb 1, 2019 10:59 AM
jstandle
Awesome, thank you! We don't have anything that old, we were hoping it would work on a D5 so we could run a bigger rotary or flail.
I don't imagine it would be worth the effort in retrofitting to work either. As Bruce P recently mentioned in my other thread, the type with their own reservoir can't keep cool very well and a D5 would work it a lot harder than the 2H. I'll let my Dad know what I have learned and perhaps we can list it in the for sale forum to find a good home for it rather than store it forever in the barn and never use it. I'm sure these are hard to find if you did own a 2H and were looking for one.
Thanks,
Jordan
Fri, Feb 1, 2019 11:40 PM
Reply to jstandle:
Thanks,
Jordan
Although it is listed for the 2H I suspect it fits a host of other units.
I don't have info on what all that PTO fits but looking at the adapter pattern for mounting a #25 CCU which looks like the same pattern it fits the 2H, 35 & 40 tractor, and later D6's. I believe it will fit the D5 as well, worth checking before you dispose.
Sat, Feb 2, 2019 4:40 AM
jstandle
[quote="Old Magnet"]Although it is listed for the 2H I suspect it fits a host of other units.
I don't have info on what all that PTO fits but looking at the adapter pattern for mounting a #25 CCU which looks like the same pattern it fits the 2H, 35 & 40 tractor, and later D6's. I believe it will fit the D5 as well, worth checking before you dispose.[/quote]
Thanks! The two lower holes that are close together made me think it would not fit the 9U/D5. I'll take the unit out to one soon and compare closer.
Is there any way to tell how much of an implement one of these could run? Would hate to scatter it trying to run a 12 foot rotary mower even if it does fit on the machine.
Thanks,
Jordan
Sat, Feb 2, 2019 4:56 AM
Reply to jstandle:
Thanks,
Jordan
I don't have any load limit specs but a 12 footer sounds a bit much. They have a habit of twisting the spline shaft if over loaded. Run it with a slip clutch for protection.
Sat, Feb 2, 2019 7:03 AM
jstandle
Thanks a ton OM! The information you have provided is very much appreciated!
We went out today and compared this bolt pattern to a D6 4R and a D5B and although the pattern for those two look to be the same, they are both different than this PTO unit.
The top and bottom bolts on the 4R and D5B cover plate are 6-1/8" on center versus 3-3/4" and 2-1/2" on the PTO. So, unless there are more holes hiding under the cover plate it appears the pattern must have changed some time after the 2H?
Here are pictures of the D6-4R;
[attachment=52586]D6 4R 1.jpg[/attachment]
[attachment=52587]D6 4R 2.jpg[/attachment]
Thanks!
Jordan
Sun, Feb 3, 2019 9:05 AM
Rd6 plower
Send a private message to Rd6 plower
Reply to jstandle:
Thanks!
Jordan
Cat 30 I think by pictures
Sun, Feb 3, 2019 10:28 AM
Reply to Rd6 plower:
RD6 plower,
You may be right, went back and looked at the 2H application and it's not that either. Doesn't have that lower tail with the two bolt mounting. Looking to see if I have something that shows the back end of the 30.
Sun, Feb 3, 2019 10:38 AM
josh
RD6 plower,
Thirty belt pulley unit.
Sun, Feb 3, 2019 1:39 PM
