PS. CAT 30 Tracks
PS. CAT 30 Tracks
Showing 1 to 6 of 6 results
sammysourous
Send a private message to sammysourous
Does anyone know if tracks from and RD4 or early D4 model will fit an PS/S model 30
Wide 20
Wide 30
Tue, May 4, 2010 11:40 AM
YeLLoIrOn
Send a private message to YeLLoIrOn
some one else may have a better answer but just measuring the two side by side I believe they would interchange. Seems like i remember the bolt holes in the pads being different so you would have to use the d4 rails. I may be wrong but i have pondered the same idea before being how my Thirty has worn out pads (and some one put them on backwards)
Wed, May 5, 2010 11:05 AM
sammysourous
Reply to YeLLoIrOn:
Thanks for that yelloiron, the bolt pattern on the plates are differant so yeah i am chasing a complete set, chains and pads, need 18 inch ones though for my wide 30.
Wide 20
Wide 30
Wed, May 5, 2010 11:19 AM
Caterpillarman
Send a private message to Caterpillarman
Reply to sammysourous:
Hello, The rails and pad bolt hole centers are 1/4 inch wider on a D-4. 30 rails/pads will not interchange with D-4 rails/pads. You can put D-4 rails and pads on a 30, but they are 1/4 inch wider, which gives you more side to side movement on the sprockets and front idlers. I have a 30 with D-4 tracks on it, and they tend to want to walk off alot. Caterpillarman
Wed, May 5, 2010 11:55 AM
YeLLoIrOn
Reply to Caterpillarman:
Thanks for that info caterpillarman. I think that i have d4 pads and rails on my thirty:mmph: I'm gonna go break out the tapemeasure tomorrow and confirm cause it jump the rails off the bottom rollers easily if you adjust the track properly. We've got them over tightened a hair and they dont jump off.
Thu, May 6, 2010 9:45 AM
Caterpillarman
Reply to YeLLoIrOn:
Yep, thats exactaly what my 30 does. I dont reccomend using D-4 rails on a 30. Caterpillarman
Fri, May 7, 2010 7:42 AM
sammysourous
Thanks for the help guys, i will keep a lookout for some wide 30 tracks i think, would really like some with 18inch pads if anyone knows of some.
Wide 20
Wide 30
Sat, May 8, 2010 5:28 AM
