Propane injection
Propane injection
Showing 1 to 10 of 13 results
Magard
Send a private message to Magard
Hey all been farming with my old d4 5t. I have a d4 7u that I'm going to
get going needs major motor work I guess it was ran out of oil. Any how been think about propane injection instead of turbo anybody have any thoughts. Just looking for alittle extra power when I hit a tough spot.
Sun, Oct 18, 2015 11:40 AM
8C 361
The horsepower on either your 5T or 7U can be increased dramatically by altering the settings for rack and rpm. Any change from factory settings is not advisable. The factory settings are carefully arrived at by Caterpillar engineers through years of testing and calculation. Any change from these settings risks destruction of your drive train and ultimate dependability of your tractor. No turbo or propane necessary.
Sun, Oct 18, 2015 7:47 PM
Magard
Reply to 8C 361:
I thought the drivetrain could handle it because cat put a d4600 engine on a d4 chassis and called it a d5. Not sure what modifications were done. That's why I thought it could easily handle alittle more. The fuel pumps don't seem to be really conducive to much fuel gian to really utilize a turbo.
Sun, Oct 18, 2015 9:31 PM
Reply to Magard:
With the right fuel injector pump camshaft and increased rack setting you can coax a little more hp out of the D4400 but with out engine balancer you are limited in rpm.
Sun, Oct 18, 2015 10:37 PM
Magard
How about the 41/2" bore. Is it a 315 or something. The engine in a 7u.
Sun, Oct 18, 2015 11:44 PM
Reply to Magard:
The 7U uses the D315 engine. Engine balancer was not added until s/n 7U26583.
Sun, Oct 18, 2015 11:55 PM
Magard
7u35268 what can you tell me about it. What year is it?
Mon, Oct 19, 2015 12:26 AM
Reply to Magard:
That 7U will have a lot more HP already over the 5T, You shouldn't need any more for "Tough Spots".
Ask anyone who has one of those "D5's" about the rear end being slopped out from too much horsepower.
Mon, Oct 19, 2015 12:35 AM
Magard
Reply to drujinin:
So that's why they only made 40 something of them.
What year would this 7u be. Just curious.
Mon, Oct 19, 2015 12:59 AM
Reply to Magard:
7U35268 mfg. is early 1956.
5T hp is 44hp @ 1400 flrpm
The 112 grader got 52hp @ 1500 flrpm (D4400)
7U29424-37284 58 hp @ 1600 flrpm
7U37285 got 60.5hp
The 3U grader got 72hp @ 1800 flrpm (D315) with different governor and spring.
For comparison the 4R/5R D6 (D4600) got 70hp @ 1400 flrpm
Mon, Oct 19, 2015 1:19 AM
Magard
7U37285 got 60.5hp
So a d4 drive train is maxed out with a strong running d315. I'll bet the torque from a d4600 is way over board. A d315 is quite an improvement on a d4400.
Mon, Oct 19, 2015 1:41 AM
