Price on D5 84H rollers and recoil spring?
Larry
Send a private message to Larry
Anyone out there have a rough price on single and double flange rollers as well as recoil springs and centre bolt? Are there any suggestions regarding OEM or aftermarket quality versus price? Thanks in advance, larry.
Sun, Apr 19, 2020 7:33 AM
gemdozer
Thank you received: 25
I have maybe 15 new bottom rollers single and double flange and some used one for D6 9U but should be the same has D5
Sun, Apr 19, 2020 6:03 PM
Larry
Reply to gemdozer:
Any idea of price? Part numbers I need are 1M3826 and 1M3827. I don't know if these are complete or shell only. Don't have a parts book at present. Larry.
Mon, Apr 20, 2020 4:46 AM
gemdozer
Reply to Larry:
My rollers are the same and these rollers are single and double flange and these are assembly and check today and am still have 13.
Mon, Apr 20, 2020 6:04 AM
Larry
Reply to gemdozer:
Gem dozer, the fellow that I was going to get the D5 from has changed his mind. Since I was interested in it he thinks it is worth mega bucks. If he changes his mind I will be back in touch. Sorry for your trouble. Hope you get better soon. Cheers, Larry. This dozer needs recoil springs on both sides. rollers, steering clutch problems, transmission problems, and a darn good cleaning. All signs of piss poor maintenance. Sprockets are also worn.
Thu, Apr 23, 2020 7:18 AM
gemdozer
Reply to Larry:
you better check for a other machine
Thu, Apr 23, 2020 5:55 PM
