Precombustion chambers
Showing 1 to 10 of 11 results
Cat951
Send a private message to Cat951
Hi Team!
ted to know, in our old caterpillar, what problems they may have the precombustion chambers? Require maintenance?
What benefit port the replacement of the precombustion chambers?
I have seen an ad where a shovel in the description says: mounted new precombustion chambers. Why can replace them?
thanks
Mon, Feb 6, 2012 8:18 PM
SpragueM
The most common failure of the precombustion chamber is rusting thru from the water jacket side. The chambers are surrounded by the cooling system. It becomes most noticeable when water begins to enter the combustion chamber and bubbles are seen in the radiator.
Matt
Tue, Feb 7, 2012 6:55 AM
Thank you received: 46
Reply to SpragueM:
Matt
With proper cooling system maintenance......mainly correct anti-freeze with anti cavitation additive.....combustion chambers will last a very long time. Where things go bad is when there are cooling system leaks left unrepaired and tap water or (ditch water) is substituted for proper coolant. Corrosion and pitting of the pre-com chambers then becomes severe to the point where pin holes through the chamber can result.
I'd be a little suspect of an engine advertised with "new pre-combustion chambers" unless it was part of a major overhaul. New chambers alone would indicate to me that there were recent or maybe ongoing problems with the cooling system.
Tue, Feb 7, 2012 11:27 PM
Colby
Send a private message to Colby
If a pre-combustion chamber was leaking and water was used for coolant, could it cause the engine to backfire/pop???
Thu, Feb 9, 2012 12:35 PM
Reply to Colby:
I'd say not very likely.....I would expect to see combustion gases in the coolant/radiator or the risk of liquid lock if water leaked back into the cylinder when setting. Also possibly steam/water vapor in the exhaust when fired up.
Thu, Feb 9, 2012 10:42 PM
hdroadkingc
Send a private message to hdroadkingc
Where would the best place to buy Pre Combustion Chambers and seals? Im in the process of replacing one due to it leaking coolant. I figure I would replace all of them while Im at it. Would it be better to go with official Cat parts or would it be fine to buy aftermarket? This is for a Cat 951C with the 3304 engine.
Fri, Feb 10, 2012 9:22 AM
Reply to hdroadkingc:
That's kind of a personal choice. In todays global sourcing it's hard to tell where stuff is coming from, even Cat. Every once in awhile I hear about a chamber coming apart but can't tell whose it is. The aftermarket versions have worked for me but I don't buy very often. Regal, Costex or Heavyquip would be typical sources.
Fri, Feb 10, 2012 11:54 AM
catsilver
There are three reasons a PC chamber leaks, 1, the engine has been overheated and the seals burnt, 2, the seals have failed due to old age, 3, the chamber has corroded away. The most common reason is the first one, when the chamber is out, look closely at its bottom seat in the head with a flashlight, if the chamber was loose, you will very likely find cracks across its seat where it screws into the cylinder head.
Fri, Feb 10, 2012 8:01 PM
hdroadkingc
Reply to catsilver:
Well I got all 4 chambers out without any problems. One of the chambers was rusted through. I went ahead and ordered all 4 chambers and seals from Florin Tractor. This should fix this problem anyway.
Thu, Feb 16, 2012 3:07 AM
Mike Walsh
What are you doing for sealing washers. I am pretty sure you have glow plugs in those pre-cups. You will need to time those pre-cups so that the glow plug holes terminate in the same location which means you will use washers with different thicknesses to obtain this result.
Thu, Feb 16, 2012 6:06 AM
Wombat
Donor
Reply to Mike Walsh:
To get the glow plugs in the right quadrant, only screw precom in by hand until it is just firm on the washer, if the glow plug is in the left half of Quadrant, torque to specifications, if not screw out and try a diifferent size washer, a bit hit and miss but you will eventually get them all in the right quadrant, have at times even tried precom in different hole to get a result. Neil
Thu, Feb 16, 2012 7:48 AM
