Precombustion chamber interchangeability
Showing 1 to 10 of 18 results
TOGNOT
I’m still looking for a precombustion chamber for my D2 3J. I have a couple leads, but in the meantime I wondered :
Are there other prechamber that maybe don’t fit ( exactly) but would with a little machine work ? Several companies make after market chamber for the bigger cats, that’s why i ask.
Thanks for any ideas.
Tue, Sep 15, 2020 7:26 AM
d2gary
[quote="TOGNOT" post=222214]I’m still looking for a precombustion chamber for my D2 3J. I have a couple leads, but in the meantime I wondered :
Thanks for any ideas.[/quote]
This is totally from memory so I can't verify any of it but I read it on the bulletin board in the past. Someone was having similar problems locating precom for a d2 and it was suggested that a d4 chamber could be turned and rethreaded to fit a d2. I don't know if this was d4400 to d3400 or if the u series stuff will work also. I can't give you the thread pitch either. I did a couple of searches with the search option and couldn't find anything. Maybe some more knowledgeable will help out
Tue, Sep 15, 2020 7:23 PM
Reply to d2gary:
Whats the bore diameter for the early chamber. If it's 2-1/8" that's the same as the early D4 which has a length of 3-1/2" from seat to top of chamber. Thread size on the D4 is 1-1/8"-12 tpi, the D2's are 1"- 12 tpi. The D4 chamber is part # 8B0493 which I believe are still available.
Any luck finding J model later chambers? Threads on the D4 chamber can be re-cut and some reshaping of the chamber transition to the threads are probably required. Basically this is the same task the rhpig offered for the later U model D2's.
Wed, Sep 16, 2020 9:04 AM
TOGNOT
Thank you - that’s what i needed - some dimensions. I don’t have the head and the removed chamber here with me, but ill find out and report back.
Wed, Sep 16, 2020 1:10 PM
Here's a picture of an altered D4 chamber for use in the "U" model D2's as offered by jhpig on here.
Similar alterations would be required for the "J" models.
[attachment=60528]Altered 1S1970 for D311.
jpg[/attachment]
Wed, Sep 16, 2020 10:11 PM
TOGNOT
Thanks for the picture. I found a drawing online for the part number you listed earlier ( 8B0493 )
Wed, Sep 16, 2020 10:40 PM
Reply to TOGNOT:
Neither the diameter nor the thread size is correct for the 8B0493 as shown in the drawing.
Wed, Sep 16, 2020 11:28 PM
TOGNOT
Gotta love the internet. Ill keep looking.
Thanks for the info.
Thu, Sep 17, 2020 2:35 AM
TOGNOT
I think I Have some Good D2 chambers Enroute . But to follow up onthis topic :
Measuring the D2. Head :: prechamber “bore” at the top about 2 1/8”. Distance from combustion chamber to top Of prechamber sealing surface :: 4.25 “
When the new/used chambers arrive I Will Document the dimensions
Thu, Sep 17, 2020 7:38 AM
Reply to TOGNOT:
That would be a match for the 8B0493 at 4.25" overall length.
Thu, Sep 17, 2020 12:40 PM
TOGNOT
New/ used pre chambers arrived. I will get all the measurements before they are installed so we can compare them to other cat models. [attachment=60591]1EBB1603-FF9B-40B8-B4C1-705FC2B7F0D2.jpeg[/attachment]
Fri, Sep 25, 2020 7:23 AM
