Pre-chamber gaskets
Pre-chamber gaskets
Showing 1 to 7 of 7 results
power stroke 99
Send a private message to power stroke 99
I was reading in the manual about setting the pre-chambers .....the ones that have the holes for the glow plugs.......The manual says their are gaskets that are alphabetically ordered for setting the holes in the correct spot so that their is not any interference......does anyone know the part number for these gaskets. I checked all of mine and one is really close to having to be moved.
Sat, Oct 10, 2009 4:34 AM
SJ
Send a private message to SJ
You didn,t say what engine you have but a later D4 with D315 engine has the following 5B3265 is .064" thickness and 3H2237 is .051" and 9F8554 is .036" and 9F8548 is .101" and 9F8549 is .090" and 9F8550 is .080" . Some have tenths after the main decimals but that won,t make little if any difference.
Sat, Oct 10, 2009 5:33 AM
power stroke 99
Reply to SJ:
Yeah....Sorry forgot to say what engine. I have a 1958 D4 cat. D315 engine. Now the gaskets you specified will all fit a 4F5508 head.......My old head had cracked and I had this one laying around so I had the machining work done to accomidate the larger Pre-chambers with glow plug holes 1S1970........also the Service manual says that they are lettered and to go to the next letter if the hole is not in the correct place.....is this correct?
Sat, Oct 10, 2009 7:13 AM
Reply to power stroke 99:
All the D4 pre-com chambers are 1-1/8 in. threaded nose.
Manual is correct on the gasket seal sequence.
Sat, Oct 10, 2009 8:34 AM
power stroke 99
[quote="Old Magnet"]All the D4 pre-com chambers are 1-1/8 in. threaded nose.
Manual is correct on the gasket seal sequence.[/quote]
Are the gaskets labeled....and are the part numbers in the thread correct?
Sat, Oct 10, 2009 9:04 AM
Size is by part number label on the package.
SJ gave you the correct numbers.
You really need to get yourself a parts manual.
Sat, Oct 10, 2009 9:25 AM
power stroke 99
[quote="Old Magnet"]Size is by part number label on the package.
You really need to get yourself a parts manual.[/quote]
Thanks.
I know I need one.....ebay?
Sat, Oct 10, 2009 9:28 AM
CarlsCAT
Send a private message to CarlsCAT
Thanks.
http://cgi.ebay.com/CATERPILLER-DIESEL-D4-TRACTOR-MANUEL_W0QQitemZ180417478425QQcmdZViewItemQQptZBI_Books_Manuals?hash=item2a01b83f19
http://cgi.ebay.com/CATERPILLER-D4-TRACTOR-PARTS-CATALOG-1959_W0QQitemZ180417478401QQcmdZViewItemQQptZBI_Books_Manuals?hash=item2a01b83f01
Sat, Oct 10, 2009 9:30 PM
