Power Unit
Power Unit
Showing 1 to 7 of 7 results
JHall
Send a private message to JHall
Howdy Folks, I picked a d315 engine the other day and need some help figuring out what year it was built. It had been sitting in a old barn on a dairy farm for quite some time but it was out of the weather. I took a big pipe wrench and a bar to try and roll her over. To my surprise the main broke free and after a full turn was free. The pony freed up by hand but doesn't have much compression if any. The inspection plates on the side of the block we're missing all but two bolts so I figured it has a bottom end problem. So when I got home I pulled the covers and found out why she had been sitting in a barn for thirty years. No2 rod had spun a bearing or something to that effect. It showed signs of heat and had plenty of slop in the bearing. The rest of the rods looked good and had some float in them. The clutch housing is drilled for electric start and I would like to use it on a D4 that I'm working on. Is a power unit housing the same as a 7u dozer housing. Thanks for your answers....Jim.
Sat, Mar 16, 2019 4:44 AM
Flywheel housing, oil pan and oil pump are not the same as the 7U. Governor arrangement and rack settings will also be different. I'd have to do more digging but I don't believe the front timing gear cover is the same either.
On further check the timing cover is the same.
If your tractor doesn't have the engine balancer the early belly pan will not fit the later engine with balancer. Would require the later belly pan.
Sat, Mar 16, 2019 12:22 PM
JHall
Thanks for the info Old Magnet you are always on top of things. Could you possibly give me an idea of what year it was built. The number on the tag is 9S11838. I guess I can use the cutch housing for measurements to cut the hole for starter in the 7u housing. If anyone needs a pan, front support, clutch housing for a D315 power unit let me know as I don't need them and I have to see good parts go to the scrap yard.
Sun, Mar 17, 2019 2:17 AM
Reply to JHall:
My listing doesn't go to that high a s/n so I'm guessing 1957, 58, or 59.
Use these dimensions to bore your flywheel housing, not sure if the Industrial Housing is the same. I was fooled by a D318 Industrial Housing not being the same as a D6.
Sun, Mar 17, 2019 3:49 AM
Chuck C
Bell housing is different power unit to d4 dozer. A friend of mine is doing the same swap.
Chuck C
Sun, Mar 17, 2019 8:06 AM
Reply to Chuck C:
Chuck C
Maybe I wasn't clear. The housings are obviously different but it's the starter hole location dimensions that I was referring to.
Sun, Mar 17, 2019 9:20 AM
hfdzl
Set up 2 rows of letters and numbers as so
N U M E R A L C O D
0 1 2 3 4 5 6 7 8 9
I can't get the spacing just right but you get the idea. The main pieces, the engine block, oil pan flywheel housing and possibly others will have a 5 or 6 digit letter code. That will transfer to the number chart. This is the casting date, and will be within a few months of later assembly. May have to wire brush or clean heavily to see. Still works today as far as I know.
Good luck,
Sun, Mar 17, 2019 4:02 PM
Chuck C
Reply to hfdzl:
N U M E R A L C O D
0 1 2 3 4 5 6 7 8 9
Good luck,
Sorry OM
Chuck C
Mon, Mar 18, 2019 12:11 AM
