Posting Photo's
Posting Photo's
Thank you received: 227
Everyone seems to have problems posting Photo's on the website. In effort to help, try the method I use which is successful most of the time. (If the photo does not show and you have an icon - try insert photo again - if the icon shows, there will be no photo attached. ONLY ONE PHOTO PER POST - (I understand this will be addressed in the future) Follow the diagram - Left to Right - top to bottom. ADD IMAGE - SELECT FILE - (file should show as in my example- INSERT - POST ---- cts
Thu, Sep 11, 2025 12:25 PM
Thank you received: 140
Hi, cts.
I would have added, if you want post photos, check to make sure that the cloudflare icon is not there ta the bottom left of the page before you start your post. If it is, click on it and go through the authentication process BEFORE you start your post. I didn't see the cloudflare icon last time I posted photos and I was told that it was going to be deleted but, util we're SURE it'z gone, check.
Thu, Sep 11, 2025 1:03 PM
Mark Riendeau
Thank you received: 34
Good greef. This website....
Sat, Dec 27, 2025 12:58 AM
