porta power with hollow plunger
n2s3
Send a private message to n2s3
anyone out there know a good place to buy a quality porta power.manual pump say 10,000 psi with the hollow plunger? I looked on the enerpac website. looks like about $1500. don't really want to buy any made in china tools, but can't really justify the $1500....unless I want to be single again. found out I needed this AFTER changing out the steering clutches on my D25U. now my chipper bearing are out.it never ends.....Bryan
Wed, Oct 28, 2015 2:20 PM
I had good luck on EBay buying one 2 years ago. I started searching there regularly for a 10Kpsi combination. What I found was usually Good quality with poor descriptions for items were the cheapest. Best sellers were the CAT cylinders that I was "Watching". I bought a cylinder that is very similar in size to a 12 ton Enerpac. I had previously acquired a nice Enerpac 5 ton push cylinder with a 10K pump. A decent Pressure Gauge and a few replacement fittings to marry the parts together was all it took. I assembled it and put it up against a Shop press with a Gauge that read in PSI and Tons. A few readings at various pressures got my gauge close enough for pressing sprockets and clutches.
Wed, Oct 28, 2015 6:35 PM
ronm
Reply to drujinin:
I got one off ebay a couple years ago for about $100, as I remember. Had a plan to make a load--control bushing puller/installer for JD tractors, but haven't ever got to it...
Wed, Oct 28, 2015 8:01 PM
Thank you received: 46
Reply to ronm:
Watch ebay for Enerpac or Simplex units.
Wed, Oct 28, 2015 9:51 PM
chuckb
well i have bought all of my enerpac and even a cat 100 ton setup from Craigslist
Wed, Oct 28, 2015 10:09 PM
mog5858
Reply to chuckb:
we Have 30 and 50 OCT one at the shop that bean used lost and still work well. do your self a favor and get a air over hyd pump sure makes life easier. but i think the 30 is still i the 1200 range. but the have 2 rams on each side and them a hole down the middle so as not to be a true hallow cylinder but work well i think i going to fab my own up but that on the some day list lol.
Fri, Oct 30, 2015 7:38 PM
