Pony Petcocks
Pony Petcocks
Showing 1 to 10 of 11 results
doc_dozer
Send a private message to doc_dozer
Is there an easy source ( outside CAT) for pony motor petcocks? Mine do not seal any more and leak like a windowscreen in a submarine.....
Charley
'44 D2 5J 6987SP
'57 D6 9U 25158
and bunch of Farmalls😉
Mon, Oct 23, 2017 7:14 AM
Mon, Oct 23, 2017 7:37 AM
bcwayne
Got mine here....
https://www.mcmaster.com/#petcocks/=19xgtph
I also use the ones from McMaster/Carr I find their #4793K64 works well.
Mon, Oct 23, 2017 8:51 AM
oldbeek
Reply to bcwayne:
Mine had a radiator drain cock on one side.
Mon, Oct 23, 2017 9:51 AM
restore49
Reply to oldbeek:
3B9067 from CAT is $11.06 with new and improved for you convenience steel body with a plastic handle. The 4793K64 is all brass. Bob
Mon, Oct 23, 2017 7:34 PM
doc_dozer
Reply to restore49:
Thank you! I’ll go for brass😊
Charley
'44 D2 5J 6987SP
'57 D6 9U 25158
Mon, Oct 23, 2017 11:42 PM
rax200
Reply to doc_dozer:
Hi all
Florin Tractors also has them, the ones from Cat are too big and will not screw onto the pony head.
Regards
Tue, Oct 24, 2017 2:16 AM
STEPHEN
You might be able to tune them up with disassembly, cleaning and lapping
Wed, Oct 25, 2017 12:07 AM
rmyram
mine have springs on them that is supposed to hold them tight, the valve is tapered and the spring keeps the tapered valve in the body. They get kind of gunked up with dirt and stuff and start to leak a little. i found you can dissassemble them and clean them up good, then stretch the spring a little bit to put more tension on it, and they work good again till the next time they get gunked up.
a lot of the air tanks use on trucks had the same style of valves for draining water. i can get them cheap at napa and they come in 1/4. 3/8 and 1/2 inch npt thread.
Wed, Oct 25, 2017 12:03 PM
doc_dozer
Reply to rmyram:
I hadn't thought about refurbishing them. I'll pull them off friday and try it! Thanks!
Charley
'44 D2 5J 6987SP
'57 D6 9U 25158
Wed, Oct 25, 2017 5:26 PM
restore49
Reply to doc_dozer:
I can loan you a little non embedding polishing compound - once you get the bottom nut off reassemble the taper and this will give a perfect air tight fit. Bob
Wed, Oct 25, 2017 7:34 PM
