Pony orientation Question
p100kman
Send a private message to p100kman
I know this is crazy to ask but frustration has set in 15 degrees and 21mph winds -5 windchill and I'm 60. I have a cat 12 9K and need to confirm which cylinder on the pony is Number 1. From rear of grader facing main engine is the cylinder on the Right the Number 1? Thanks for your patience!!
Sun, Jan 19, 2020 1:49 AM
Yes
#1 is on the side with pony/pinion controls
Practically it doesn’t matter much since the pony is an even fire design. If you have it timed to the wrong cylinder, simply swap the plug wires in the magneto cap.
Sun, Jan 19, 2020 4:02 AM
Thank you received: 79
Yes
also as a further check the yellow SRB says it is the one nearest the pony flywheel.
Sun, Jan 19, 2020 6:07 AM
p100kman
Reply to edb:
[quote="edb"]Hi Team,
Eddie B.[/quote]
Always appreciate the help!!!! Just wanted to make sure I was correct in my thinking.
Tue, Jan 21, 2020 11:40 PM
