Pony Motor Starter
Pony Motor Starter
Showing 1 to 10 of 19 results
WayneB
Send a private message to WayneB
Have pony shield for starter. I am flying blind. I have a parts book and there are more than a handfull of starter motor combinations, without main starter, with direct starter and glow plugs, etc.
Was this a delco starter-generator? Been looking and found many starter generators available. Is this the standard CCW rotation?
The bracket for my sheild looks to mount a delco starter generator. I notice in the parts book the starter pulley is not clutching , but plain. If it was also a generator, this is explained.
Wayne
This is to mount on a D6 9U (D6 9U 11919)
Sun, Jun 13, 2010 9:26 PM
gemdozer
The startor is bolt on the bracket 9b1756 and the sheild 6b9914 is bolt on the bracket and has a gear inside 6b9909 for recieved the startor pinion and the startor is lock on the bracket by a big screw
6b2712 on the bracket side and the bracket is bolt on poney manifolf intake.
Mon, Jun 14, 2010 12:26 AM
WayneB
Reply to gemdozer:
gemdozer,
Do you have the parts?
[quote="gemdozer"]The startor is bolt on the bracket 9b1756 and the sheild 6b9914 is bolt on the bracket and has a gear inside 6b9909 for recieved the startor pinion and the startor is lock on the bracket by a big screw
6b2712 on the bracket side and the bracket is bolt on poney manifolf intake.[/quote]
Tue, Jun 15, 2010 5:08 AM
WayneB
Reply to WayneB:
gemdozer,
Got a starter with it of sorts.
I have a jack-legg setup using a Ford starter and pulley, long arm that mounts on fender with 2 bolts/hinge, cross the belt to turn the engine the right way. I'll get it started once I get the magneto and carburator rebuilt.
Wouldn't mind a starter kit for the Pony. In gear pulling, down hill starts EZ. Uphill sux. :rolleyes2: Unfortunately, I don't have level ground. After pull starting dozer with my 50-60HP 4x4 tractor, I will invest efforts to get the pony working. I tore up some pasture grass!:mmph:
Wayne
Tue, Jun 15, 2010 5:20 AM
gemdozer
Reply to WayneB:
Wayne
I have the sheild ass. and the bracket and I make sure tomorrow for the startor.
Tue, Jun 15, 2010 5:47 AM
WayneB
Reply to gemdozer:
Do you have a starter to mount the sheild, bracker and bolt. In my book, I believe that was combo # 3 without lights, there were many other parts. Do you have enough of the parts to mount a starter on the pony?
Wayne
Tue, Jun 15, 2010 7:49 PM
Thank you received: 46
Reply to WayneB:
Wayne
This is what the pony starter installation looks like.
The shield assy is the starter to belt drive.
(Read up on your manuals about installing the drive belt, it's a bit tricky)
This is the starter and mounting bracket (unique to D6)
There is only one starter drive arrangement, the rest is choice of with or without battery and choice of generators.
There is no use of combination generator/starter motors.
None of the parts are interchangeable with the D4/D2.
Tue, Jun 15, 2010 10:49 PM
gemdozer
Like OLD MAGNET you just need bracket, startor,sheild ass with betl and puley and switch and I hope you have a poney flywell with 2 grove and am still have these parts.
Wed, Jun 16, 2010 1:20 AM
WayneB
A picture is worth a thousand words.
Gemdozer, let me know if you have it.
Dick is also checking, he may have everything for the starter.
This weekend, I am pulling the hood, timing the pony and pulling the magneto and carb for rebuild. Looks like I will need to pull the fuel tank and clean & coat it.
Again, thanks. The books I have do not illustrate this starter like those pictures show.
Wayne
[quote="Old Magnet"]This is what the pony starter installation looks like.
None of the parts are interchangeable with the D4/D2.[/quote]
Wed, Jun 16, 2010 9:49 PM
cojhl2
Reply to WayneB:
Wayne
[quote="WayneB"]Got a starter with it of sorts.
Wayne[/quote]
Actually you should be able to turn that starter the other direction by reversing the cables on the motor. We used those starter motors to run headers and thru solenoids ran the motors both directions.
Wed, Jun 16, 2010 10:13 PM
WayneB
Reply to cojhl2:
Wayne[/quote]
Not going to invest too much into this setup. If it works it works.
Tested the starter. IMHO it does not spin fast enough with 12V. Was boosting it off my Gator. I did the old 2x4 against the pulley test and it had strength but the RPMs seem low. Will use my tach gage this weekend.
It will certainly do better than that rope.
Wayne
Thu, Jun 17, 2010 4:36 AM
