Pony motor running, one big step for me.
Showing 1 to 10 of 13 results
Karlmonard
Send a private message to Karlmonard
Vídeo following, next step, changing oil, filters ECT. I have read on here I should add a pre filter on fuel, any suggestions? Should I remove cover on oil pan and clean screen? The injector pump is over full of oil, does this mean fuel is leaking in the oil, the fuel tank was bone dry. Setting 18 years. Should I regasket something or try it forst. Thanks for all the help I got to get the pony running.this is a great group, looking forward to meeting some of you. I tried to upload a video, couldn't figure it out, could someone let me know how to.
Thu, Jun 7, 2018 5:17 AM
old-iron-habit
Gee. Lets all guess what kind of machine this post could be about. Maybe we could get a new clue each day. 😊 😊
Thu, Jun 7, 2018 7:06 AM
Thank you received: 90
Reply to old-iron-habit:
Hmmmmm. I’m guessing it’s a Caterpillar?
Thu, Jun 7, 2018 7:17 AM
TOGNOT
Disregard the grumpy old guys.
Congrats on getting your pony going. Everyone like pictures, maybe include your serial number. Sounds like you did some searching on here already... LOTS of info to soak in.
Welcome !
Thu, Jun 7, 2018 7:35 AM
daron
Thu, Jun 7, 2018 8:19 AM
old-iron-habit
Daron wins. I must be getting old. I commented on the other post about the serial number even. It was a couple months ago. Good job on getting the pony running.
Thu, Jun 7, 2018 8:55 AM
I’m never grumpy! Jack’s comments to the OLD grumpy from MN. Just trying to add some levity to his post; I doubt that grump meant anything snarky about it....
Yes, excellent on the pony running. Me like. Post pictures now. Lots of them. Please!!! JM
Thu, Jun 7, 2018 9:07 AM
daron
One of the easier ways to deal with video is to upload and link to youtube.
Daron
Thu, Jun 7, 2018 10:59 AM
Regarding the injection pump housing overfull.......only thing I would do right now is ensure the drain line from the upper compartment where the lifters are is open to the ground. It usually is connected to another line by a t fitting so you might have to disconnect one OT the other branch and run a wire up it, use compressed air etc. Leakage from the pumps should collect in the upper chamber and be channeled to the drain.
If you have a plug in the governor end of the pump housing fuel gallery that runs along from front to back under the engine side of the pumps, it can leak into the governor and collect in the oil sump. It uses an 8b4967 o-ring just like the one between pump housing and fuel filter housing. That one usually leaks directly into the engine oil so it is a more immediate problem. Late models didn't have a casting with an opening on the governor end, so no plug seal to leak.
Oh ......change the diluted? oil! If its the fuel gallery plug seal, it will quickly fill the housing again while it's running and has fuel pressure.
Thu, Jun 7, 2018 11:06 AM
TOGNOT
Yes, Juiceman is correct, it's a compliment.
Thu, Jun 7, 2018 9:02 PM
Karlmonard
Reply to TOGNOT:
Sorry guys I didn't know the system didn't give you my information.its a D4 serial 14525 with a HT4 traction shovel serial 1864. Trying to up load video on u tube now. First time for me, so don't be surprised​ if it doesn't work. https://youtu.be/AlC6ExZgLXI
Thu, Jun 7, 2018 9:21 PM
