Pony Motor interchange? D-7 17A to D-7 3T?
Winch Cat
Send a private message to Winch Cat
My D-7 3T has a stuck pony motor from a few owners ago. I am looking at replacing it with the pony motor out of a D-7 17A IF, and only IF, the 17A pony motor will work in the 3T.
Fri, May 4, 2018 9:13 PM
gemdozer
Online
Thank you received: 11
The 17a poney is't fitting on D7 -3T and you could removed your 3t poney and check the trouble on.
Sat, May 5, 2018 1:04 AM
