pony motor head bolt torq spec
digger
Send a private message to digger
Can any tell me the spec for head bolts on a pony motor on a 318 cat, is there any order i should torque them in also? thank you.
Wed, Jan 30, 2008 4:21 AM
Thank you received: 39
There is no specific order for tightening....just use standard torque value for the size of fastener.
Wed, Jan 30, 2008 4:56 AM
Thank you received: 29
here is are some scans from my tension wrench booklet showing generic sequences etc.
Generally start in the center and spiral outwards, I like to come up to full torque in three steps and a further run around at full torque just to be sure.
Also retorque after first run up when hot and again after 5 or 6 starts, the old copper asbestos gaskets shrink away after a while and start to leak.
Hope this helps.
Wed, Jan 30, 2008 6:50 AM
