Pony motor fuel issues
Showing 1 to 10 of 11 results
valerie-verboncouergreen-7560
Send a private message to valerie-verboncouergreen-7560
Pony motor will start, but will only run on choke. When I let off choke it starts to die. Carb adjustments don’t change its performance. Here’s what I’ve checked so far: magneto timing, fuel lines, sediment bowl assembly, governor arm moves freely, also have new spark plugs. It will get fuel but at other times does not have enough fuel in system to get to carb. Any other troubleshooting ideas?
Thu, Aug 20, 2026 3:43 AM
PhilC
I had similar issues with my D6 pony motor and it turned out to be a blocked intake from mud daubers.
Thu, Aug 20, 2026 9:24 AM
CrawlerAddict
Thank you received: 14
You may want to inspect the idle jet. With today's 10% and now 15% ethanol gasoline things can get crusty quick. I've had the same issue multiple times on various machines and found that shuttin the fuel off and letting the carb run dry and out of fuel rather than just turning the mag kill switch after startup helps a lot. Along with using a good fuel conditioner such as Lucas ethanol fuel stabilizer which is pretty much mandatory these days in preventing such issues.
Thu, Aug 20, 2026 12:40 PM
Thank you received: 78
Only runs on choke means not enough fuel for the vacuum seen in the throttle body, assuming you mean at high idle, not low idl. Causes can include what PhilC said about the fuel bowl not seeing atmospheric pressure (blocked vent), what CA wrote about crust-causing ethanol gas, partially blocked main jet system (jet in bottom of bowl, galleries in bowl body, brass nozzle in throat). If it's also at low idle, same things apply. If it's only at low idle, then the idle jet (more of a plug really) adjacent to the throttle plate when closed can be blocked or not oriented correctly relative to the plate - it has to see vacuum to work when the throttle is closed. My approach is to start at one end (nozzle or float valve, doesn't matter) and work methodically through the carb, checking everything in the flow sequence. Doing that, you will find the cause. Don't forget that the gaskets are important, including the "bullseye" gasket between the float bowl and the throttle body. It has an inner ring and an outer ring - both must be in good shape, and the two ring surfaces on the throttle body and fuel bowl must be level relative to each other. For the galleries, you drill out the plugs, clean the galleries (I use twist drill bits in my fingers to feel the crud vs. the metal of the fuel bowl), then replug using .177 cal BB pellets. Some dab a small amount of epoxy over the plugs as insurance - I haven't done that but also don't have any leaks. For the main jet distribution nozzle in the throttle body throat, carefully unscrew it. They can be quite stuck and it can take a lot of patience to get it out without damage. Soaking in carb cleaner, ultrasonic, etc. can help free things up. Use a flat grinding surface to true up the bullseye surfaces. To remove the idle jet, with the throttle plate held open, use a closely matched side punch to drive it into the throttle body. I've re-installed with the notch down (engine intake side) so that I know it will see vacuum when the throttle plate is closed but it all depends on the idle speed setting how open that plate is. Let us know what you find. Remember to be methodical, take your time and inspect closely, and you will be rewarded with a good running carburettor.
Thu, Aug 20, 2026 1:07 PM
Thanks for the quick responses. I airblasted all carb passages and checked gasket seals. I am running non- ethanol fuel. From looking at past forums, I saw recommendations to clean out emulsion tube. I did that as well.
Any other suggestions as to what could be the problem?
Thu, Aug 20, 2026 3:52 PM
Couple more things to check - the gaskets on the manifold, both at the interface with the carburettor, and on the block. If you remove the carb, you can check that interface for sealing issues, and while you have it off, you can spray the join to the block with soapy water and pressurize the intake manifold to rule out leaks there. Also, are you confident that the float level is suitable? There's a measurement for an edge of the float but I don't have it to hand - it might be on the site somewhere. A better measurement, if it could be taken, would be the actual fuel level. Failing that, you could check what level the float maintains in a bowl of fuel then calculate what that would make it with the float installed on the top cover upside down resting against the float needle
Thu, Aug 20, 2026 7:38 PM
Thank you received: 227
Have you ensured the fuel is getting to the needle/seat in the carburetor bowl without restriction? Clean fuel tank, clean lines and sediment bowl/filter? You need good steady flow to the carburetor.
Thu, Aug 20, 2026 8:06 PM
Checked all gasket seals, but will not continue running at low idle. It wants to keep running at full throttle regardless of throttle setting. When pulled to idle, it will either turn off or stay at full throttle. I have to use choke to keep it running at low idle. No carburetor adjustments change the way it runs. Engine has been overhauled. All linkages are in proper places .
Fri, Aug 21, 2026 3:38 PM
Running at full throttle sounds like you are getting plenty of fuel, not running at low speed (idle) and no carburetor adjustment makes me think the low speed jet, is not working properly, the needle valve adjustment not changing points to that same issue. Choke at low rpm is enriching the mixture, in effect overriding the low speed fuel delivery. - cts
Fri, Aug 21, 2026 10:20 PM
Thank you received: 95
it has been found in the past that the Idle Discharge Jet is clogged with fine sediment. The jet needs to be very carefully removed to clean out a machined ring area in the body of the brass fragile jet that the sediment fills over time.
To removed said jet it must be gently punched into the throat of the carby whilst ensuring that the throttle butterfly is fully open--if its closed the jet will be destroyed. Clean out the passages leading to the jet bore---re-insert the jet until it is even with the throat wall--if you go too far punch the jet out and start again--DO NOT try to punch the jet back into the body from the throat side or it will be destroyed. See attachment for details of said jet orientation by the vertical ridge on its outer end, note also the positioning/orientation of the 1 or sometimes 2 nicks that are the jet orifices on the end piece at the throat end and you will see how they interact with the throttle plate at idle.
Check also the long idle jet for blockage or breakage and maybe re-welding blocking the internal passageway, check also the idle jet and passageway in the bottom of float bowl--mentioned above by others.--some model carbs. do not have an idle jet in the bowl.
Encountered something like you symptoms and the carb was blamed but it was issues with the spark system be it magneto, spark plugs, leads, timing--two reco. carbs were tried and re-inspected several times before the owner was finally convinced to check the ignition system in its entirety.
Sat, Aug 22, 2026 1:11 AM
Sat, Aug 22, 2026 1:14 AM
