Pony Motor bearings
Pony Motor bearings
brainsboy
Send a private message to brainsboy
I started rebuilding my pony motor which is a 2 cylinder for a 2T. It uses the crank 4b903. I looked in the past posts and found a place in california which might have the bearings but they need a part number. The main bearings I pulled do not have any markings. Any one happen to have the part numbers for these bearings?
1943 D4 -2t6377
thanks
Wed, Oct 26, 2011 2:16 AM
Thank you received: 19
Is what your looking for standard or undersize?
Wed, Oct 26, 2011 6:23 AM
brainsboy
Its going to have to be undersized on the mains, but if I can get any part number for any size that will be a good start
Wed, Oct 26, 2011 7:08 AM
Reply to brainsboy:
Flywheel end crank 0.020 under is an 8B0006 RPB 4F9416
Other end 0.020 under is an 8B0005 RPB 4F9413
Wed, Oct 26, 2011 7:25 AM
brainsboy
Thanks for the information. As it turns out the place in california says they can no longer get the main bearings. I have a lathe and mill so Im going to be making my own main bearings. Im going to just have the crank grinder cut the crank just until the journals are smooth again and then i will custom make each side of the bearing for a perfect fit. I was able to find to the rod bearings and piston rings so things are going pretty good.
Thu, Oct 27, 2011 5:06 AM
Reply to brainsboy:
6061-T6 aluminum seems to work well but don't make the clearances to tight.
Thu, Oct 27, 2011 8:27 AM
Thank you received: 23
Not sure if the 4T pony bearings are the same as the 3J ones (the 4B903 crankshaft part number is the same) but if they are, I just bought, from Caterpillar, one bearing for ~$90 and the other for ~$100. They're available at least for the 3J. My engine rebuilder estimated about $50 to $100 for custom bearings made from Oilite (bronze-ish) so for bought bearings, the OEM ones seem ok.
Neil.
Thu, Oct 27, 2011 9:05 AM
brainsboy
Neil.
Thanks for the info, I actually had ordered some 6061 aluminum. But I was actually thinking this weekend about maybe converting the pony motor to roller bearings on the main crank.
Sun, Oct 30, 2011 7:29 AM
Reply to brainsboy:
Your not the first one to think of that.....way back when the D17000 engine (locomotive service) was coming into use it had the grand daddy of large horizontal twin pony motors and the main bearings were roller bearing. Didn't work out for long as they had a habbit of rusting up when out of service or infrequently used.
Sun, Oct 30, 2011 9:23 AM
