Pony head gasket
Pony head gasket
johan7
Hi , My 3T D7 pony motor lost compression after it had started the main engin . I suspected the head gasket and that is correct . Just between the 2 cilinders the gasket is leaking , pushing air from one into the other . Is there anyone who experienced the same ? The Netherlands , Johan7[attachment=20176]gasket.jpg[/attachment]
Thu, Oct 24, 2013 12:45 AM
Soapy
Send a private message to Soapy
Check the head surface, making sure it is flat, and not warped in the center.
Thu, Oct 24, 2013 12:53 AM
Thank you received: 93
Reply to Soapy:
Hi Johan,
also check that the head stud threads are clean and that the nuts can be screwed on all the way down easily.
When installing the nuts, put a drop of oil on each stud thread and torque to specification.
After the first start re-torque the nuts and then again after about 10 starts. These old style multi layer gaskets are known for compressing down and the nuts loosening off.
Thu, Oct 24, 2013 5:56 AM
johan7
Reply to edb:
Hi Johan,
Hi , thanks for the info , quite useful ! But retorqing after some time is easier said than done . You have to drain the cooling system in order to remove a waterpipe and the manifolfds to get at the head nuts . Anyhow , I have had the head flattened to be sure and installed a new gasket . Thanks again . Johan7
Mon, Oct 28, 2013 9:46 PM
