Pony Fires better on one only
Showing 1 to 10 of 11 results
auscuscus
Send a private message to auscuscus
On my D4 5T pony I get a really good spark out of each plug.
With both leads on it will only idle. If I remove #2 lead, the pony fires to full speed running just on #1 Cylinder.
If I swap the #2 lead over to #1 , it does not race on it's own.
What does this mean ?
Thu, Jan 13, 2011 7:25 PM
I think either the wrong magneto or more likely a magneto cap problem allowing the spark to track between the two lead connections. Removal of the #2 lead could help isolate the #1 side so it gets a good spark.
When you say you swap the #2 over to #1, are you talking about swapping the whole lead or just one end. In the case of swapping the whole leads, something is surely suspect about the #2 lead unless you mean that you connect both leads again once you swap them and the original problem returns. After you swap the leads, if you remove the old #1 lead from the #2 cylinder will the engine rev up or not?
Fri, Jan 14, 2011 2:54 AM
lrolla
Send a private message to lrolla
I'm experiencing the exact same symptoms on my D2 pony. I took the mag out, and had it checked out. The shop that examined it told me that the coil needed to be replaced. I put the repaired mag back in and it fired right up but it only ran for about a minute before it started to act up again. Same thing again, it will run on one cylinder but when I have both wires hooked up to the plugs it won't start.
I'm going to pull the mag again and take it in. I have a feeling it's the problem. I would also try disconnecting the grounding wire at the Mag that goes to your kill switch. This would eliminate one more potential problem.
Let me know if you solve the problem and I'll do the same.
Larry
Larry Rolla
Sat, Jan 15, 2011 2:34 AM
auscuscus
[quote="ccjersey"]I think either the wrong magneto or more likely a magneto cap problem allowing the spark to track between the two lead connections. Removal of the #2 lead could help isolate the #1 side so it gets a good spark.
When you say you swap the #2 over to #1, are you talking about swapping the whole lead or just one end. In the case of swapping the whole leads, something is surely suspect about the #2 lead unless you mean that you connect both leads again once you swap them and the original problem returns. After you swap the leads, if you remove the old #1 lead from the #2 cylinder will the engine rev up or not?[/quote]
Ah well there was a serious burn/ gouge mark inside the cap. I filled it with epoxy a long time back. ( like it got hit by magneto lightening... ) I took the mag several times to a place that rebuilds them for drag racing cars. I always assumed a mag issue, but they ran it with a drill and showed me the output on the test bench and it was hard to argue. Would a continuity test between the two electrodes show up a cap fault or does it need the great out put of the mag in full flight to bridge any fault ?
Or could I test continuity ( a bridge - conductivity ) by putting my multimeter probes in each mag socket and pulling the starter cord ?
I might try running it in the dark and see if any escaping blue flashes ?
When I swapped the leads I left them in the mag ( as they were ) and routed them to the opposite plugs. I then went on and tried all different combinations , which eliminated a lead issue. The only one that revs at full speed is left mag to left #1 Cylinder.
Does it elimate a timing issue as I can get one cylinder to run at full speed ?
I very much appreciate the advice. Doctor for 7 years now I have suffered this cat disease. I am only 41. I am I too you to go this way ?
Sat, Jan 15, 2011 9:12 PM
If you swap the wires on a running D2/D4/D6 horizontal or an even fire vertical pony motor and it still runs, you definitely have spark jumping from terminal to terminal.
Your timing should be right or it wouldn't run on either one very well.
With spark jumping from terminal to terminal in the cap, you have a "wasted spark" ignition. The sparks occur at ~15 degrees before TDC compression #1 and TDC exhaust #2 and then at ~15 degrees before TDC exhaust #1 and TDC intake #2.
The jump must be easier one way than the other to cause the difference in performance when you swap the wires. Something about the epoxy is acting sort of like a zener diode, it resists current flow in one direction more than in the other.
With one of the odd fire verticals, I could see how the mag might be timed for the following cylinder spark to hit the leading cylinder plug, but that would put the leading cylinder spark into the intake stroke of the following cylinder (I think, getting my self confused here😆 and would almost certainly cause it to backfire through the carburetor.
Get a new cap and put it on there!😆
Sat, Jan 15, 2011 9:41 PM
ol Grump
I think you've found your problem when you described the "magneto lighting strike" inside the cap that you filled with epoxy. It would have been better if you had ground the strike mark out as it probably carbonized the cap along that track. While a VOM probably won't show continuity due to the low voltage it uses, high voltage such as used in the mag will follow that track.
Back when I was young, we used to take a pencil and mark a distributor cap with a light mark from several of the plug wire towers either to each other or to the edge of the cap to the distributor housing itself. Sure causes some interesting misses (and noises) as the juice would arc along those marks 😆
Yup, get a new cap.
Sat, Jan 15, 2011 10:01 PM
Tim Matthews
Send a private message to Tim Matthews
Reply to ol Grump:
Yup, get a new cap.
Mine did the same or somthing very simalar , end up being a worn impulse coupling. Make sure it snaps for both cylinders. Tim
Sun, Jan 16, 2011 10:13 AM
Reply to Tim Matthews:
No Impulse coupling on the D2, D4.
Sun, Jan 16, 2011 10:28 AM
auscuscus
Reply to ol Grump:
Yup, get a new cap.
[quote="ol Grump"]I think you've found your problem when you described the "magneto lighting strike" inside the cap that you filled with epoxy. It would have been better if you had ground the strike mark out as it probably carbonized the cap along that track. While a VOM probably won't show continuity due to the low voltage it uses, high voltage such as used in the mag will follow that track.
Yup, get a new cap.[/quote]
Is this the best place to start for a cap ? Bill L at www.magnetoparts.com
I am in Australia so it has to be mail order.
Have attached a pic before I filled it. I wonder if the epoxy is conductive itself. I will grind it out and have a closer look at the original short. What else can I fill it with ?
Sun, Jan 16, 2011 2:03 PM
ol Grump
Reply to auscuscus:
If you're going to grind it out, I'd use a Dremel tool with a tiny stone rather than a metallic burr. Reason being that any metal residue from the tool would also act as a conductor.
As far as epoxy being conductive, I really don't know. If there's any metal filler in the epoxy, it would probably be conductive. I'm not sure I'd even mess with filling the ground out area. .unless the cap would be too thin.
A pencil eraser works well for cleaning things up as (I think) it has a fine abrasive in it. That's what we used to clean up the pencil marks on distributor caps when someone marked it up😆
Sun, Jan 16, 2011 9:39 PM
B4D2
Reply to auscuscus:
[QUOTE=auscuscus;69048]Is this the best place to start for a cap ? Bill L at www.magnetoparts.com
/QUOTE]
You can also try Standard Magneto http://standardmagneto.com/
Mon, Jan 17, 2011 12:34 AM
