Pony engine part numbers
Rowey
Send a private message to Rowey
Hello , I am chasing a part number for a rear main bearing on a pony engine on a D73t . I have a spare pony but it runs a rear main seal instead of an oil screw.i thought I would use this crank in my pony and get my pony block main line bored to accept the seal and shorter main bearing . My parts manual only gives me the part numbers for oil screw type bearing ,many thanks rowey
Fri, Jun 19, 2020 5:43 AM
seiscat
I have the parts books for all of the 3T D7 tractors. let me know what you need to interchange.
Fri, Jun 19, 2020 8:02 AM
Rowey
Reply to seiscat:
Hello seiscat , I am after a part number for the rear main bearing on a pilot motor that uses a rear main seal many thanks rowey
Fri, Jun 19, 2020 9:46 AM
Thank you received: 91
Reply to seiscat:
scans are all I have on a Field fix to add the rear seal.
The Service Magazine Jan 30-1953 tells of a first release expensive seal addition method.
Service Magazine May 07-1954 tells of a cheaper method.
Service Bulletin July 19-1955 gives all the Part Numbers for the Field Change Over Group and Special Instruction Form No 137-30912-02 for fitting said group.
The Dealer Tech Service dept or Parts Manger should be able to supply a copy from Micro Film--hopefully.
Everyone with a D7/8 of the period should copy and save this as this stuff can disappear over time.
Hope this helps.
Fri, Jun 19, 2020 10:17 AM
Rowey
Reply to edb:
Hope this helps.
Many thanks for your help Eddie B, I have learnt a lot from the update and I am very pleased that I won’t have to line bore the block to fit a seal ,have a great day ,rowey
Sat, Jun 20, 2020 9:19 AM
STEPHEN
Reply to Rowey:
A few months ago I tried the dealer for the field upgrade parts and nothing is available & they don't even know what I'm talking about. I think you could get the seal in a CR seal, and use a speedy sleeve or machine a thin wall sleeve for the journal
Sun, Jun 21, 2020 9:50 AM
