Pony Engine Crankshaft seal
Showing 1 to 10 of 14 results
farmallzach
Send a private message to farmallzach
The pony engine crankshaft seal (behind the flywheel) is leaking on my 7T (D4600) grader engine, how big of a job is this to fix? I have the complete power unit removed from the grader, I am swapping engines from one grader to another. Also some oil ran out of the bell housing when I lifted the engine out of the parts machine today, any advice here would also be appreciated, Thanks, here are some pictures of me removing the engine today. ๐Ÿ‘
Tue, Jul 5, 2011 9:46 AM
anyoldiron
Send a private message to anyoldiron
....................gotta love a excavator, its only when youve got one you wonder how you ever managed without.
Tue, Jul 5, 2011 9:50 AM
farmallzach
Reply to anyoldiron:
It sure worked better than the 2 fork lifts I used to remove the other engine, it was very effortless, took me about an hour to do the whole thing.
Tue, Jul 5, 2011 9:52 AM
zootownjeepguy
Reply to farmallzach:
The seal is not a hard job, pop the flywheel off and it's right there. Scary thing is that usually if the seal goes it means that the bearing has left and taken the seal with it. Check the bearings, if the crank bearing is worn out, your new seal won't last long.
Good Luck!๐Ÿ‘
Rich Salvaggio
D2 5U9917
Tue, Jul 5, 2011 10:29 AM
Rennix
Send a private message to Rennix
Reply to zootownjeepguy:
Good Luck!๐Ÿ‘
Wow Zootown,
Thanks for the great news. Both of my pony motors have leaky seals.:rant:
1953 D4 6U8588 Cat hyd. blade, Hyster D4 winch
1959 955 Traxcavator 12A6595
1959 Rogers/Phelan 25 ton lowboy
1960 D7 17A14922
Tue, Jul 5, 2011 8:23 PM
zootownjeepguy
Reply to Rennix:
Wow Zootown,
[quote="Jeffreytoddrennix"]Wow Zootown,
Thanks for the great news. Both of my pony motors have leaky seals.:rant:[/quote]
Yeah, I hate to be the bearer of bad news, ...er, well it's not so bad news if it's not my equipment.๐Ÿ˜†๐Ÿ˜†๐Ÿ˜†๐Ÿ˜†๐Ÿ˜†
Seriously, if the bearing is a bit loose it will destroy the seal and that goes for just about anything mechanical. My D2 pony had a crank seal that would dump a pint of oil about every 7 minutes of running time and you could watch the flywheel bouncing up, down and all around as it ran (but it still RAN right up until it threw a rod). I'm at the point now where I need to rebuild one of my other pony motors to put on it. So many projects, so little ambition, I mean,...so little time.
Rich Salvaggio
D2 5U9917
Wed, Jul 6, 2011 3:50 AM
farmallzach
The bearing seems good and tight, I can't move the flywheel up and down on this one like I could on the engine I am parting out.
Wed, Jul 6, 2011 7:54 AM
Oletrapper
Send a private message to Oletrapper
Hope someone has this thread tagged as it is old. Well, we shall see.
Seal behind flywheel is leaking. This D4 sat for 12 years in a field. Pony motor runs great after a little fuel tank cleaning etc. but leaks oil from behind flywheel. We keep oil added whenever we start it. I am fairly certain seal has just dried out from sitting. Main engine runs great. My question- Can the seal behind the crankshaft flywheel be changed without pulling the pony motor.
Thanks, Oletrapper 1952 D4 7U
Tue, Mar 1, 2016 9:53 PM
TOGNOT
Reply to Oletrapper:
My D2 pony seal was leaking too - I pulled it out and found it was leather. SO, it might just be old like mine was. Got a new one from Cat, about $6 or $7....
Wed, Mar 2, 2016 12:30 AM
Yea, it can be done.
Of course remove flywheel first and then you can either remove the whole front plate that has the seal and main bearing so the seal can be driven out from the back or pried out with a big screwdriver....
or carefully drill a hole or two in the seal and screw a sheetmetal screw in to pop the seal out with a small bar, claw hammer etc. Be especially careful to avoid any damage to the sealing surface of the crankshaft while drilling or prying out the old seal.
Need to critically evaluate the state of the bearings and how much slack there is both side to side and in and out. Might be false economy to just replace the seal if there is a lot of slack.
D2-5J's, D6-9U's, D318 and D333 power units, 12E-99E grader, 922B & 944A wheel loaders, D330C generator set, DW20 water tanker and a bunch of Jersey cows to take care of in my spare time๐Ÿ˜„
Wed, Mar 2, 2016 3:21 AM
so the bearing can be replaced by just removing the plate??
Wed, Mar 2, 2016 3:35 AM
| Kingaroy, Queensland
