Pony Carburetors
Pony Carburetors
Showing 1 to 10 of 13 results
Dieselholic92
Thank you received: 14
Since it's a nice day out, I'm going to get a plan together for spring. I'd like to get the pony motors on my D7-17A and D6-9U running. Where could I find carburetor kits for these two?
David Gruhot
D & G Excavating, Inc.
Tue, Jan 31, 2017 2:20 AM
gemdozer
You can have some kit from caterpillar dealer and from zenith carburator and if I can help am still have some used carb.in working condition
Tue, Jan 31, 2017 4:02 AM
rmyram
on my 9u's, all i did was drill the bottom passage in the float bowl to clean it out good with a drill bit, then soldered the hole shut again. CC jersey (i think, correct me if i'm wrong) uses BB's with finger nail polish to reseal his units. I also installed a new float that i ordered from cat and it worked fine. the needle and seat were ok, as were the throttle shaft bushings. everything else i cleaned out real good. reassembled units with new gaskets (also from Cat) and they purred like a kitten after. they would start with full choke, and the little spring thingy worked to open the choke after it fired off. they idled good and pulled good under load, did not require choke to be partially on to keep engine running at idle or under load.
Tue, Jan 31, 2017 5:20 AM
Dieselholic92
Reply to rmyram:
Thanks for the replies. I'll go see what my Cat dealer can get.
David Gruhot
Tue, Jan 31, 2017 6:16 AM
old-iron-habit
Reply to Dieselholic92:
I drilled the lower passage lead plug out just a whisker smaller than an air rifle pellet and tapped that back in. Has not leaked yet in a couple of years.
Tue, Jan 31, 2017 6:47 AM
Thank you received: 39
I would get mine here, but lead time is required.
Tue, Jan 31, 2017 6:48 AM
mog5858
the carb shop has them too. look at ordering but still just been getting by with just a good cleaning lol and being lucky. don't you need one for that 318 that's not in you 6 😉
http://www.thecarburetorshop.com/
Tue, Jan 31, 2017 7:30 AM
STEPHEN
Reply to mog5858:
[quote="mog5858"]the carb shop has them too. look at ordering but still just been getting by with just a good cleaning lol and being lucky. don't you need one for that 318 that's not in you 6 😉
http://www.thecarburetorshop.com/[/quote]
Yes, but they only answer the phone on Monday & Tuesday! Really! And have a bigger list of what they won't do for you than what they will. However they do list a lot of applications. Let us know what you find out
Tue, Jan 31, 2017 7:57 AM
Dieselholic92
Reply to mog5858:
I do need one for that too. If I remember right, they are the ones that rebuilt the carb on my D6 2H.
David Gruhot
Tue, Jan 31, 2017 7:54 PM
restore49
The Green tractor people also have parts - used on the pony for a diesel farm tractor.
Tue, Jan 31, 2017 9:05 PM
ag-mike
this is the guy i use too.
http://www.mcdonaldcarb.com
Tue, Jan 31, 2017 9:14 PM
