pony carb settings
pony carb settings
robin
Send a private message to robin
I rebuilt the carb on a D7-3T but can't get gas to the plugs. Does anyone know the preferred settings. I left the idle but replaced the guts for the intake. The old 7M carb was 3.5 turns. The non-working carb was 10.5 turns. Suggestions?
Mon, Feb 24, 2014 9:13 AM
Most carbs are 1 turn open as a starting point. If you cannot choke it and get gas into the cylinders, you have a fuel supply problem, not a carb adjustment problem.
Mon, Feb 24, 2014 9:08 PM
Bruce P
I'll second what ccjersey says.
I would first be certain you are getting fuel to the carby bowl. This would eliminate a plugged sediment bowl or fuel line.
If that checks out and you still can't get fuel to the plugs, you have one or more plugged circuts. A simple carb cleaner soak will not always open up the passages, some times you have to root 'em out.
I had a post on this topic in the thread "7m 298 comes home" perhaps that would be of interest.
Good luck
Bruce P
Tue, Feb 25, 2014 12:00 AM
