Pony Carb Identification
Showing 1 to 6 of 6 results
dtcohen
Send a private message to dtcohen
Hi All,
I need to get a rebuild kit for the pony engine carb on my d4 2t. I called the carburetor shop (listed in the parts source thread) and the told me I needed to get the numbers off the round tag so that they could get me the correct rebuild kit. That sounded reasonable, so I went and looked at my carb. I found the little round tag, but there are no numbers on it. Can somebody please advise me on what the correct cat and zenith part number would be for this carb?
Mon, Oct 12, 2015 10:49 PM
STEPHEN
The original Zenith carb kit is K609 . They should
be able to work with that.
Mon, Oct 12, 2015 11:35 PM
ronm
Reply to STEPHEN:
Tag on my D2 carb says: 5F3527. Under that is: 0368B.
the kit I got is: K2067, but no brand name, I got it from my carb/mag guy...he was glad to get rid of it...
This is the carb w/the super-duper/monkey-motion/mousetrap/reset/spring-loaded choke, like your pic...
Tue, Oct 13, 2015 4:42 AM
dtcohen
Reply to ronm:
I talked to the guy at the carburetor shop again. He couldn't look up anything based off of the pictures or the kit number. Cat dealership was able to give me the Cat PN, but not the Zenith number. I also didn't have much luck looking up the engineering drawings at work.
The guy I talked to at the carb shop did tell me that it wasn't unusual for caterpillar to remove the tag and turn it upside down if it was sent to them for rebuild. I suppose my next move is to try to get the tag off and see if the numbers are on the other side.
Tue, Oct 13, 2015 10:04 AM
STEPHEN
Reply to dtcohen:
I suggest trying a different shop, it is really not that hard and these guys are supposed to be experts. Are they just going out of the way to be difficult?
Tue, Oct 13, 2015 10:21 AM
ronm
Reply to STEPHEN:
yeah, somebody's not trying very hard.
http://www.autotestsys.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=ATS&Product_Code=K2067&Category_Code=ZCARBKIT
http://www.mcdonaldcarb.com/product_p/k2067.htm
Tue, Oct 13, 2015 10:46 AM
Original carb for the 2T is a 8B3917 = Zenith #9790
Replaced by a 5F3528 = Zenith #10367
Yours is an original.
Tue, Oct 13, 2015 11:02 AM
