Pony carb float bowl screws.
Dozerman51
What thread size are the pony motor float bowl screws on a D2/3J carb. Thanks for any help.
Sat, Dec 2, 2023 5:29 AM
Thank you received: 60
If your referring to the float bowl lid screws they are #10-32 tpi. Two at 1/2"length and two at 3/4" length. Run a tap to clean the threads.
Sat, Dec 2, 2023 8:12 AM
Dozerman51
Hello Pete. Thanks for the info. Hope you are doing well. 👍👍👍
Sat, Dec 2, 2023 8:19 AM
Thank you received: 54
Reply to Dozerman51:
a light smear of grease on the tap will trap any shavings or crud. its a old trick and it work well in blind holes. and it lubes the tap you can also use rocol paste etc too
Sat, Dec 2, 2023 12:27 PM
Dozerman51
Reply to trainzkid88:
Thanks for the lube tip. 👍👍
Mon, Dec 4, 2023 3:22 AM
PhilC
Don't use grease. Use a proper cutting compound. Grease is designed to stop things cutting a tap is designed to cut.I know a lot of people will use grease but it can actually be detrimental to the cutting edge of the tap.
If you have an air compressor just blow the hole out with air. (safety glasses of course)
Mon, Dec 4, 2023 2:52 PM
| Kingaroy, Queensland
