Poking through the weeds and backwoods again...
blackdog006
Send a private message to blackdog006
I found today an older D6 for $8500 the owner says that he has a large enough tractor to pull it off and he will see if he can get it running in a week or so 😄 When I go back I will bring my camera and get pictures for everyone I stopped at this place when I spotted something yellow in the weeds in the front of the property (it turned out to be an Oliver dozer 😕 :mad😊 I mentioned I was looking for a Cat and he said he had a 6 parked out back that he would sell 😄 Now if only I can figure a way to raise the 10-12 K I need to get this fueled/lube it and transport to the first job site 😞 😕
Fri, Apr 9, 2010 11:24 AM
83Jim
Send a private message to 83Jim
This group is always up for the challenge of evaluating something found in the weeds.
You only need two tools in life - WD-40 and Duct tape. If it doesn't move and should, use the WD-40 If it shouldn't move and does, use the duct tape.
Cat D4D 83J w 3304 PC engine, FOPS, s/t blade, D4F winch, air ride seat, "wobble" stick blade lever and D8H control panel
Cat 920 62K w 3304 PC engine, FOPS, 4 in 1 bucket
1995 Dodge Ram 2500 4x4 RCSB Cummins 5 speed
Fri, Apr 9, 2010 7:43 PM
| Kingaroy, Queensland
