Plow day
Showing 1 to 10 of 11 results
kracked1
  [attachment=64319]e5e7a541020468a12b9fe125406a4d35[/attachment]Local plow day yesterday. My D47U and tandem plow set up I put together. 5x14 worked great.
Tue, Aug 17, 2021 8:19 AM
D4Jim
Nice picture and particularly of the two plow hitch setup.
Cats Forever
Tue, Aug 17, 2021 8:36 AM
Sasquatch
Thank you received: 5
Reply to D4Jim:
Nice setup! I’ve been dreaming of an on-land hitch to pull two 3 bottom plows in tandem behind my RD6, I think it would be great fun. Is that Gary in the seat?
Tue, Aug 17, 2021 10:09 AM
kracked1
Reply to Sasquatch:
Good eye, that is Gary. He came down to see it in action and had to make a round. I can help if someone wants to build one.
Tue, Aug 17, 2021 5:42 PM
bursitis
Reply to kracked1:
i have a JI Case 5x16 drag plow. since my D46U is narrow gauge can i adjust things to pull this as an onland set up?
Tue, Aug 17, 2021 8:28 PM
gauntjoh
Librarian
Thank you received: 8
Reply to bursitis:
I believe that with a crawler you should always plough “on the land” rather than in the furrow. Do not pin the drawbar so it can swing freely and adjust the plough drawbar so the plough pulls straight.
Tue, Aug 17, 2021 9:24 PM
Thank you received: 78
Reply to gauntjoh:
I'm looking forward to plowing with my 5U this fall - I haven't used anything but wheel tractors previously. I'm running slicks on it so I'm not sure if I'll be able to put all the power : ) to the ground but it's in sandy loam so I'm sure it'll be fine. The bigger problem I'm guessing will be trying to keep straight lines!
Tue, Aug 17, 2021 11:39 PM
kracked1
Reply to bursitis:
[quote="bursitis post=230688 userid=10813"]i have a JI Case 5x16 drag plow. since my D46U is narrow gauge can i adjust things to pull this as an onland set up?
That will have the center of draft at 46.5 inches from the inside of the furrow wheel. 5 x 16=80/2= 40 +4.5 inches (which is the magic number for 16 inch bottoms to compensate for average draft) +2 inches for clearance between furrow wheel and furrow wall.= 46.5 inches. Set the plow drawbar as straight as possible so your hitch pin is at 46.5 +- an inch or two. Your 6U should be 68? inches wide which would be 34 to center. 46.5-34 =12.5 inches from furrow wall. Also with a crawler having the hitch so low you need to set the point where the hitch hooks to the main frame of the plow as low as it will go. Other wise it will want to pull the back of the plow out of the ground.
 [/quote]
Wed, Aug 18, 2021 8:06 AM
bursitis
Reply to kracked1:
 [/quote]
thank you very much.
Wed, Aug 18, 2021 9:14 AM
D2MOVA
Send a private message to D2MOVA
Reply to kracked1:
 [/quote]
Have probably replied to this before but you have to remember trailing ploughs were originally pulled by horses they could not steer them I have ploughed acres and acres with a D2 and a 3 and 4furrows on flat and hill country always the tractor on the land drawbar sliding from centre to the right when it gets steep turning uphill you just move toward s the furow to keep the plough in line will try and post some photos
Wed, Aug 18, 2021 9:18 AM
kracked1
Reply to D2MOVA:
D2MOVA I have been told by a few old timers thru the years that if set correctly you could pull a plow with a chain.
Wed, Aug 18, 2021 5:32 PM
