Please Identify this D4
YellowDogRes
Send a private message to YellowDogRes
Looking at this cat and seller says it's a 7U like I wanted. There is no tag on the back and it looks alot like the 5T with a D4400 not the 315 a 7U would have. The air filter is like a 4400 and the starting levers are like the 4400's. I'm 99.9% positive it's a 5T but would like a definite yes or no. Is there another tag spot besides on the back? Thanks[attachment=43510]00z0z_2q8etOFIYN5_600x450.jpg[/attachment]
Sun, Jul 16, 2017 1:49 AM
Thank you received: 23
The other tag location is behind the governor on the main engine block, just below the block to head join. If the tags are missing, you'll see two small holes where the drive pins secured the tags. Carefully scrape the paint off between them to reveal the serial # stamped into the block.
Doesn't look like a 7U to me - has the large governor housing on the front, straight pinion clutch lever, air cleaner inlet at the front of the hood, small bearing case on the final. There could be 7U parts on it, but the engine, hood, and finals do not look like a U. What % of parts would deem it a U vs. T? I'd argue that the main engine and the transmission/final/undercarriage would need to all be U-series to qualify, otherwise it's a combination and should be advertised as such.
Sun, Jul 16, 2017 2:09 AM
YellowDogRes
Thanks for the reply. I have a complete 7J and a 7u that's in pieces, was hoping this would be a 7U but all the facts are pointing towards a 4400. Under the impression it was a 7U I Told the guy I would buy it, but on the drive home the air filter location kept popping in my mind. Owell. Rookie mistake! Haha
Sun, Jul 16, 2017 2:40 AM
catsilver
Reply to YellowDogRes:
Its a 7J or early 2T?, small outer final drive hub bearings and governor in the timing case tells me.
Sun, Jul 16, 2017 3:28 AM
Thank you received: 19
Reply to catsilver:
Governor in the timing cover makes it a 4G or 7J prior to s/n 7J5104.
Track frame says it is above s/n 4G9902.
Sun, Jul 16, 2017 12:56 PM
