please help with identification of engine
Showing 1 to 10 of 11 results
1951D2
Tue, Nov 17, 2026 12:59 AM
1951D2
Tue, Nov 17, 2026 1:00 AM
1951D2
1951D2
1951D2
These were sent to me from a friend and I am not familiar with it.
Tue, Nov 17, 2026 1:01 AM
Thank you received: 95
that would be the D340 4 cylinder version of a 6 Cyl.-D343, and a V8-D346, 5.4 bore X 6.5 stroke engine, similar to that used in the 619C, 824 etc.
They were not a very successful chop down engine.
Tue, Nov 17, 2026 1:55 AM
1951D2
Thank you so much Eddie for the quick response.
Tue, Nov 17, 2026 2:47 AM
Thank you received: 78
Is that the coolant pump mounted on the flywheel housing?
Tue, Nov 17, 2026 2:07 PM
Neil,
yes, these inline engines have a rear timing train between the flywheel and the engine block.
Tue, Nov 17, 2026 10:51 PM
7FB
Send a private message to 7FB
I want to be careful about contradicting the more knowledgeable older guys, but on the photo of the right hand side of the engine I counted 6 exhaust ports and 6 fuel injection lines. That would make it a D343, would it not?
Mon, Nov 23, 2026 4:38 AM
Thank you received: 227
I too went to Photoshop, tried to enhance and enlarge the photo. I count 6 exhaust ports easily, the left most two injector lines are not easy to see but are there. Also noticed a pair of Vise-grips on the throttle linkage, Could not enhance enough to read the firing order on the exhaust manifold. Interesting thread. Thanks Everyone--- cts
Mon, Nov 23, 2026 4:50 AM
