Pitch please D 82U
Pitch please D 82U
Manx Kat
Send a private message to Manx Kat
Please help. I may be going to see a D8 2U in a day or 2 and was wondering if someone would be kind enough to tell me what the pitch is on the tracks?
( measurement pin center to pin center would be new ) and what is considered worn out? Also is pad overlap or lack thereof a good indication of pin and bushing wear?
Thank in advance for your help.
D.K. in S.K,
Wed, Dec 20, 2006 7:33 AM
The old D8's had a track pitch of 8 in.
100% worn would be a four link measurement of 32.87 in. or 8.2175 per link.
Pad overlap is somewhat of an indicator if the rails and pads were a matched set.
Also note position of the front idler adjustment as a quick eyeball check.
Watch out for the famous missing link trick.
Good luck with your shopping.
Wed, Dec 20, 2006 8:05 AM
